bartko09
- Joined
- Apr 11, 2015
- Messages
- 535
snowlover91 said:!
Regarding the removal of the pill, it is quite easy. Mine has two small circular holes you can put some needle nose tweezers into and it unscrews right out. The emitter for the swap would need to be reflowed onto the existing copper board as its a unique design with two "wings" that stick out into the pill to prevent the led star from moving when it's twisted on/off. If you don't reflow it onto this original one I imagine it would cause issues with led centering and other things as well. Mine didn't seem to have any glue, it took a little force but nothing extreme.
Thanks! What about pulling the led/driver all together? Does it look doable? I assume it's the same model pill as the other rev 3's if so I'm sure I could do it Again [emoji2]
