Gents,
I need some guidance and education for an LED project I’m working on. I’m definitely not an electrical engineer but I love to learn about things. I’ve been doing a huge amount of reading trying to learn everything I can and my head is about to explode from too much information! So, it’s time to get some advice on whether I’m pointed in the right direction.
Project: make some underwater LED lights for my boat. The plan is to have probably two fixtures, one on each side of the transom (rear) of the boat. Underwater LED’s are available but they can get very spendy. Since I’m naturally a diy’er and I have CNC equipment I can make the housings myself. The fixtures will be under water so heat dissipation should be no problem with aluminum housings.
Output: I would like to have each of the fixtures produce at least 2,000 lumins preferably. There are ones available to buy at this level (>5,000 lms) so I know it can be done. I really want the highest lumins, brightest lights, I can make while still being reasonable in cost and current draw. The color needs to be green. I would really like dimming capability but if it adds too much complexity maybe some simple levels of power/brightness.
Considerations: I would really like the current draw for each fixture be no more than 3 amps, so if I had two fixtures the total draw of the lights would be 6 amps. From my reading it looks like I can drive them with my standard 12v system which wouldn’t work well because the amp draw would be too much. I could use a DC/DC step up system to up my voltage and reduce the current. Or I could possible use the 110 VAC system on the boat to really lower the current draw. The only drawback to an AC setup is I could only run the lights when at the dock or when the generator is running.
LED’s: I’ve looked at several emitters like Cree’s X-Lamp, BridgeLux, Osram, and Luminus. So far I’ve narrowed it down to the SST-90 from Luminous. Am I on the right track here? One slight wrinkle is the need for green color so please keep that in mind.
Drivers: Depending on what the best approach you guys think is between 12v, stepped up 12v, or AC the following are some potential solutions for drivers:
http://www.candlepowerforums.com/vb/showthread.php?327770-100-watt-CC-LED-Driver-for-12
http://www.candlepowerforums.com/vb...able-10A-linear-LED-driver-limited-quantities
http://www.candlepowerforums.com/vb/showthread.php?321013-DC-DC-70-Watt-LED-Driver
http://www.candlepowerforums.com/vb...icient-5A-9A-Buck-Converter-for-SST-50-SST-90
http://www.taskled.com/
So, I’d really like to get your opinions on what’s the best approach for me to take? Are there other LED’s I should be looking at? Given my current draw requirements do I have to use a stepped up DC or AC driver? Any guidance and information is greatly appreciated!
