I would like to show you the new Terminator which is a 10 W Mini HID flashlight avaible with rechargeable battery pack or running on 3 CR123A cells. I wrote about this new version before, finally here it is!
Before I write down the technical details here some pictures:
Now the technical details:
T500
Non-rechargeable tactical 10W HID flashlight
Feature: High intensity discharge lamp
Working voltage range: 6.3 - 9.0V
Battery: CR123A Battery x 3
Output / Runtime: 500 lumen max @ 50 minutes
Construction: Aircraft grade aluminum CNC machined, hard anodised finish, O-ring sealed, high transparency optical lens
Switch: Tactical button switch
Housing diameter: 25.4mm
Bezel diameter: 45mm
Tail cap diameter: 38mm
Length: 206mm
Weight including battery: 280g approximately
Water resistant: Splash proof
Package: Gift box
Optional accessories:
A. T1 - holster;
B. GF-gun cable switch tailcap;
C. M-Red filter, 600nm;
D. M-IR filter, 850nm;
E. M-UV filter, 365nm.
T500R
Rechargeable tactical 10W HID flashlight
Battery: Li-ion 150A Rechargeable battery x 2
Charger: C2 fast AC Charger, 3 hrs
Output / Runtime: 450 lumen @ 45 minutes
Length: 206mm
Weight including battery: 300g approximately
Package: Gift box
A. T1 - holster;
E. M-UV filter, 365nm;
F. D2 12V DC charger.
The light is very new, it had been released some days ago. So I had no chance to take a look at it by myself but I am visiting Microfire and also order the light for resell. But more about that in the dealing section where it belongs to. I will make some beamshots and comparsions with the other Microfire lights and also a video showing the startup. Maybe I can also organize a passaround when there is enough interest
David
T500
Length: 206mm
Package: Gift box
A. T1 - holster;
T500R
Length: 206mm
Package: Gift box
A. T1 - holster;
David
