Overclocker
would be interesting how they got 100 lumen bump from 6%
lemme guess, the same place where they get their fake graphs from 😉
Help Support Candle Power Flashlight Forum
Unfortunately....
Almost identical max output...
If I understand correctly, the EA4 had an XM-L U2, and the EA41 has an XM-L2 T6. From what I know of Cree's binning system, the U2 is supposed to be about 20% brighter than the T6, so maybe this isn't too much of an emitter upgrade after all. I'm going to double-check my measurements, but doubt the EA41 is going to come close to 960 lumens.
So what you're saying is the EA4 is actually brighter/better than the EA41?
Well, you can decide for yourself which of those runtime plots you like better. On Turbo, the EA41 has a very slightly higher brightness at the start, but then spends more time at a lower brightness level so that the run lasts longer. In real world use, if you're on Turbo for 15 minutes or so at a time you'll see the EA41 spending more time at higher brightnesses. Overall, I like the UI of the EA41 much more, with it's dual switch and a real low-output mode.
If this light isn't hitting its 960 lumen mark its going right back..combine that with its quality issues I'm very disappointed in buying this. And my delivery time is 10-25 business days.
Respecting your opinion, what would you consider a fair scale for reference? I have a few "Bubba Tests" as part of my inept evaluation.
*Bedroom Wall Test: If the sucker surpassess all my other high-performance lights, it wins.
*Backyard Tree Test. If the previously-mentioned sucker lights up a treetop from (rifleman's guessitimate without SS) maybe 200~210 meters, it's an amazing thing to hold in my hand. If it get's on a commercial flight, we're rockin.
*The little blue indicator under the switch membrane is uber-cool. Changing batts in pitch blackness is easy to do by feel, even in a 4X, when you know the drill. Plus, the soft blue indicator lets you know when a batt swap is immenent.
*My experience with many modern lights tells me 2M water seal-out is a conservative estimate for this offering.
Overall rating is, this is a light EVERY HOUSEHOLD SHOULD HAVE. A year of available battery power will be available provided you use the lockout procedure. Otherwise, bet on two seasons. Unless you like to play with it.
which of course is my recommended break-in plan. Guys, get this light, get a buddy to bring HIS (Or HERS!) and set the EA41 on the third level. Bet some beer that yours can go higher than he other one... You win.
I just got a new EA41, and the one confusing part is the blue light. I keep having to go thru more button presses to turn the blue location beacon on, so I guess it's OFF by default???
