Hi
I recently purchased this light and I'm I'm very happy with it. I absolutely love the UI I think it's perfect and relatively easy to use, even for people using the light for the first time. The overall quality and the finish is great and you can tell that the manufacturer has gone to great lengths to make sure it's a quality item (ie meticulous application of silicon grease to the threads). The light does have a bright hot spot and throws further than expected with a great and usable spill. I love the flashing blue light and like the fact that now with the EA41 you choose to have that on instead of it being on by default and draining the batteries so Nitecore have put thought into this light but as mentioned before, I think the UI is spot on and the light is absolutely perfect in every aspect of it's design. (I especially love the lockout mode which prevents my 1-2 year old niece and nephew from blinding themselves when they get a hold of one of my lights).
One minor concern I had was the accuracy of the battery indicator. The other day the light wouldn't go into High or Turbo mode and the blue light kept flashing rapidly when the light was on indicating a low battery (which was resolved by changing the batteries) but the battery indicator was flashing 3 times when I turned the light off and pressed the mode button to ask for remaing power which according to the manual indicated > 50% power remaining
I'm not sure if others have noticed this but the strobe mode is not consistent either. It requires a keen eye but the flickering speed changes slightly (sometimes it lags) and randomly with occasional bursts of higher output lumen on some flicks. I'm not sure if the manufacturer knows this and designed it that way or if it's poor manufacturing but it is there and it'd be helpful if someone actually did propper measurements with a graph to show?
These are minor things that don't really affect normal use of the light but I can see how it might pose a dilemma for some...
Regards
Milo
