AardvarkSagus
Not entirely certain if this goes in General or LED, but for what it's worth I just found out about a new Parat light (by Pila) that looks quite intriguing:
Parat PL 4
This one looks quite intriguing to me. What do you guys think?
Parat PL 4
Parat Brochure said:If police officers' safety is of concern – PL 4 duty-light is the answer!
PL 4 'Polizeilampe' is the day-to-day duty light developed in response to specific demands received
from European Police Forces with the objective to greatly increase the safety of police officers on patrols
including when operating in areas where explosive gases might be present (Zone 2, ATEX 94/9/EG).
Tested and approved by police units, PL 4 fulfils all operational
requirements including tactical handgun shooting -
Reinforced polycarbonate housing
Bright LED light rated at 170 lumens
Four selectable Functions set by rotating bezel – Modes are
activated by press/release silent tail-switch (no click!):
1. Safe Storage – OFF (no power consumption).
2. Rapid Situation Assessment – Off temporary ON 100% light
3. Self-defence / Immobilising – Off temporary FAST STROBE
4. Working Light – ON, 100% light 10% light, constant (toggle).
Asynchronous fast strobe for complete disorientation.
'Low Battery' warning (blinking red LED)
'Click' sensing and visual mode alignment indicator (red LED)
Continuous operation at 100% light around 5 hours and over
25 hours at 10% light with one battery set.
Automatic 'power save mode' if flashlight is not used.
Powered by 4 x standard alkaline (AA) or 4 x rechargeable NiMH
batteries.
'Speed-loading' battery cartridge for quick battery replacement.
Drop resistant and waterproof to 1 m.
Lanyard attachment with automatic safety release
Overall length 192 mm. Handle oval shape (39 mm x 33 mm).
Weight excluding batteries – around 168 grams
Specifications:
Housing : Reinforced polycarbonate, black
Dimensions :
- 192 mm length
- 52 mm diameter at bezel
- Diameter handle oval – 39mm x 33mm
Weight : Around 169 grams (excluding batteries)
Light Source : High Power Quality LED (Cree)
Light output : Around 170 lumens (peak); around 20 lumens in dim mode
Operation Time : Around 5 hours at 100% or > 25 hours at 10%, continuous.
ATEX Certification : Gas Zone 2, II 3G Ex nA IIC T2
Others:
• CE, RoHS and REACH compliant
• Battery Indicator (red LED, blinking when low on batteries)
• Speed-loading battery compartment with polarity indication
• Quick release rubber ring for attaching lanyard.
• Patent Pending and Registered Design
