As luck would have it (luck?) I had one of these spotlights appear out of nowhere, and flopped in my car. 'bout time something went right. 40 bucks with a coupon code. Here's the short version of a review:
The halogen bulb in this beast is designed for automotive headlamps. The low power setting utilizes a filament with a cupped deflector beside it, to widen the beams on a car. Worthless on a spotlight, as nearly 30 percent of its light is blocked, resulting in an off center (bulb is not oriented properly) black arc in the beam. Time to pitch the bulb, and get something designed for spotlights.
The reflector surface appears spun like a cymbal, resulting in circular ridges that appear in the beam. A different effect, reminiscent of looking at a tree's age rings, with a very hot spot in the middle. I thought the '60s were out. This freaks me out.
The battery, of course, has much diminished capacity from being neglected too long on the shelf. I bought the light, because I have two 12V. 7AH hobby SLAs...exact replacements.
Nice enclosure, however. Everything is rubber, except the gray plastic, and the bottom stand/handle. The bottom stand/handle does have a rubber coated center bar, for non-slip grip.
The "area" LEDs embedded in the bezel, will light a small space. Think no bigger than a small dining room. Was disappointed in the LED area array. Hmmpphh.
This is a 40 buck spotlight, folks. Its well-made outside hides what's inside, until you turn it on. "Holy-Toledo, Batman! Where's the beef?"
I actually started laughing when I turned it on; the tree rings freaked me out, but the long reach of the spot redeemed it...a bit.
The spot takes center stage on this light. Everything else is just...well...smoke and mirrors.
EDIT: The light saw its first use tonight, against a skunk. The reflections off the back of the skunk's eyes were haunting; almost like two LED lights looking back at me. That was the end of the reflections, I'm afraid. Dispatched.
Charles
