Mine neither :twothumbs
Neither does mine (140T)
Help Support Candle Power Flashlight Forum
If you look at the level charts, you can figure out the approximate pattern of levels. It looks like the 200 will use the same level program as the 140 with one additional upper level (My math comes out to about 199lm). Or, perhaps, a low level was eliminated. I hope not. I'll let you know when mine arrives. 😀
Dang, I just ordered a custom 170T and all this talk about the 200 is making wish I would have waited for a 200. I recently joined this forum and I'm not sure I can afford to keep logging on.
Part 5 :thinking:
Is the Ra 200 going to be limited?
B/c I plan to get one, but not now.
Hi there just a few little questions, when you shake your light can you people hear the tailcap switch making a "rattling" noise? Also sometimes my ra executive doesnt seem to register some of the clicks is this normal?
Thanks
Part 5 :thinking:
And: weren't there rumours about a natural anodizing for the Clickys? I would like to see this!!! Anyone with infos!?
Do you have locator flash turned on?
Mine does not rattle, thankfully.
I am going to have an XP-E R2 5000K put into my Ra clicky EDC Exec.
Neither I nor the modder are sure if it will work or not.
Does any of the Ra guru's on this thread care to give me predictions?
Not sure what the beam will look like but I hope it to be close to the Seoul beam.
I know the XR-E would look awful in the Seoul reflector, so it's out of the running!
If this works out I ought to gain a brighter light and have a warmer tint.
What say you?
They are currently very limited. However, look back to when the 170's were limited. Advancing technology of light efficiency shows that the 200's will eventually become commonplace. Once the 170's were run by raffle, and only a select few own them. Now, they are the third most owned type of clicky (only the 140-CGT and 140T/CN have more I believe). As time went on, they became more available. This will most certainly be the case with the 200's.
When the 200's become commonplace, I hope there will be something a hell of a lot brighter out![]()
:devil:If we take the alternating scale, then by then we will be seeing Ra 240CNs and maybe into the future, Ra 280C's...:devil:
Thanks
