NEW released IMALENT MS18 "Ambassador of light" with 100,000lumens and 1350meters
imalent
Well-known member
Manufacturer
Shenzhen
1.
MS18, “Ambassador of light”,utilizes18 pieces of American CREE XHP70 2nd LEDs with a maximum output up to 100,000LM and long range up
to 1350 meters, MS18willbringyouabsoluteshockinthenight.
2. The multi-functional OLED display can show various parameters and settings.
3.Built-inheatpiperadiatorwithexcellentheatdissipation,andequippedwithan inlet and outlet fan silent,waterproof,heavy wind , which is a perfect
combination of great energy andtechnology.
4. With IMALENT’s unique design with bright plating process optical reflector and 18pcs CREE XHP70 2nd LEDs,the MS18 delivers a max output up to 100,000 lumens and a far reaching distance of 1350meters, push you boundaries day and lights,makeita perfectsearchandrescueflashlight!5. TheMS18featuresIMALENT’ssignaturehigh-gradesidepressureswitch.This ergonomic design provides an unprecedented level of grip. Eight output levels ensure long runtimes with low or high output in any situation. The “hide strobe” featurekeepsyousafebystartingquicklyatcriticalmoments.
Utilizes 18 pieces of American CREE XHP70 XHP70 2nd LEDs , with a lifespan of up to 50,000 hours and a maximum output up to 100,000 lumens.
Built-in safety self testing intelligent charging circuit, convenient,fast and safe.
Eight levels which can be exchanged quickly and instant Turbo.
Built-in switch indicator lights, easy to find the switch in the darkness
Size: 265mm (length)*129 mm (head diameter) *59mm (body diameter)
Net weight:1900g(battery included)
High efficiency constant current circuit will maintain constant brightness.
Built-in thermal control module will automatically adjust the brightness output, keep using comfortably.
Combination of toughened ultra-clear mineral and anti-reflective coating glass Aluminum OP reflector.
Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface treatment
IP56 standard waterproof
IMALENT Official store:www.imalentstore.com
richbuff
Well-known member
Supporter
Prescott Az
Re: NEW released IMALENT MS18 "Ambassador of light" with 100,000lumens and 1350meter
1050 views and no replies?
Maybe bigger font is needed?
Well, anyway, I got mine to complement the Imalent R90TS that has beam performance and beam profile that is tops in my book.
This light is currently the one that builds the most amount of sheer power excitement!
BVH
Well-known member
Supporter
CentCalCoast
I agree. Got this a week ago and really like it. Great for people who have large parcels of land with animals who need to be able to see them from long distances at night.
