That was the first reaction I had as well....followed closely by sheer admiration at your inner geek in action 'needing to know.' See now because of your contribution, we all have absolute certainty with photos.Yup. That shows my dedication to the hobby and attention to detail. Either that or it just provides further evidence that my brain does not work right/normal
You actually cut open a brand new mag to figure out what screw was in there?![]()
:bow: :bow: :bow:
This is pretty funny. I cannot think of any reason for them to change the type of setscrew to a somewhat obscure torx type that they know most people's tool set won't fit...other than a lame attempt to foil people like us wanting to mod them. I never had the hex (Allen) type strip, and have tightened/loosened hundreds of them.
I think the issue is something else. On The High Road Forum ( mostly about guns) a poster had issues with several Mag lites all new that did not work. intermintent light and such and a used one that fell and quit working but was having issues as well before the fall.
I suggested that the issue might be the switch had come loose and that he tighten the switch. I explained how in detail.
Later the poster found that this was indeed the issue all along and the light works just fine now and he posted a great big Thank You.
Torx's were developed as the screws heads were failing before reaching the desired torque needed on aircraft screws is my understanding.
Torx and Torx Plus allowed the screws to be tightened without the tool walking out of the screw and destroying the head. This has been a widespread change in industries all over. I guess Mag Lite just finally got with the program.
Perhaps that is a more generous and accurate explanation. However, this scenario is why Maglite made the internal circular slot and retaining ring clip to block forward advancement, and punched/drilled an indented hole for the conical setscrew to fix into. If they had such a concern as you suggest, they could have put a dab of loctite on the threads.
I can only go by my own experience, and some of my mags have had the same switch assembly removed and tightened as many as 25-30 times without ever stripping the hex wrench threads. I have never had one come loose or lose contact with the aluminum wall.
Then there is all the negative historical baggage of how Maglite has aggressively sued so many as a regular business practice, the telephone conversations about this issue I described earlier, the complete lack of providing a torx key to customers when they knew full well that none of the torx wrenches people have would fit, none available for sale to anyone when asked...and upon being disconnected after the fundamental information was provided, the lady calling me back and quite rudely letting me know she had my name and number from caller ID, and wanted my Maglite serial number.
But, perhaps you are correct in your interpretation.
