Robocop
Mammoth Killer
I was able to fit a Dorcy AA board into the head of a new style infinity and it is powering a low dome lux. This is completely reversible to go back to the factory 5 mm LED at any time by simply un-screwing the bezel and replacing the factory part. I polished the bezel and it gives a good flood type beam and I later hope to find a better High Dome Lux to replace this donor Low Dome. The light keeps all the original functions with the twisting of the tail cap to activate it.I simply soldered a positive and negative wire to the Dorcy board and then potted it nice and flush with the top lip part.I then filed down a dime for a heat sink and attatched the negative lead and positive lead.The Dorcy board just fits perfect and makes good contact with the inside of the bezel for the ground contact.I did have to drill out the bezel opening a little to fit the Luxeon however when replaced with the original 5 MM LED it works just fine.I know have an Infinity Lux that I can switch at random back to factory specs.The photos are a little crappy as my cam is not the best but you can get an idea of just how cool this little mod was to make....I just have found so many uses for these little Dorcy AA boards....In a few of the pics you can see the factory board and 5 MM LED.You can see that the Dorcy board is almost exactly the same diameter and height of the factory part....easy mod to do and a lot of fun.
