frisco
Well,..... A few weeks ago I took delivery on my new "Super Spacer" After working with my lathe for a little bit, I found it's (my) limitations. Having a full size mill and small lathe (Grizzly 10x22) I really felt there was something missing. These were two separate tools with two separate duties and nothing really to connect then together.(At least in my head as I figure out how to machine something)
Discovering the "Super Spacer" was new to me. I have a rotary table for my mill and I love that..... I knew what a "Indexer" was (That round plate with all the holes in it scared the P out of me!) I knew I could put a lathe chuck on my rotary table.... But it would end up being 200lbs. I had seen Indexers with a lathe chuck on it.... But never with the rotary table cranks on them.
So now.... For those of you who don't know what a "Super Spacer" is....
It's a true rotary table with a lathe chuck mounted to it. It can be used horizontal or vertical. What makes it special or "Super" It comes with a set of plates that mount in the back of the rotary table. You can set it up for 2-3-4-6-8-12-24 stops per revolution. Ha Ha this is awesome!
Now I feel much more is possible between the mill and the lathe! I can now chuck a bigger piece of round stock in the Super Spacer and hog it down to a size my lathe likes in minutes. I can now mill flat sides into flashlight bodies and motorcycle parts.... And on and on....
The part you see in the chuck now is a tool that fits into a motorcycle front axle so you can loosen or tighten the nut on the other end. I might have enough of these sold to pay for my "Super Spacer" on it's first run.
frisco
frisco
