Battery Guy
Greetings Everyone,
I received my first of the newer 1500x Eneloops last week (purchased here) and ran them through some constant current discharge measurements in order to compare the performance to the older Eneloops.
As always, I spot weld nickel tabs to the cells to minimize contact resistance, and all testing was performed on a Maccor Series 4300 battery tester.
I had hoped that the newer Eneloops would have better high current discharge performance (e.g. less voltage sag), but it looks like they are equivalent or even slightly worse than the older Eneloops.
Here are the discharge curves for 2-10 amp discharge:
So, it appears that there is really nothing particularly great about these new Eneloops except for the reported improvement in cycle life and self discharge rate, both of which require considerable time to test reliably.
Cheers,
BG
Cheers,
BG
