New vs. Old US
The newest UltraStingers have the head threads on the outside of the body, while the older ones have the threads inside of the body.
--dan
There are also some differences in the reflectors. I have an "old" Us serial number in the 17000 range that was a demo when it first came out. I bought the demo off of the LEO supply store and got new battery bulb and chargers. They just switched out the bulb and batt in the light. I wanted the older one because it had the orange peel reflector like the surefire p series lamps. Makes for a lot smoother beam... I know that the others with a more smooth reflector are a bit brighter but i could not tell a sig. difference
Bushman,
I don't think that that smooth reflectors actually make a torch brighter - but they will make a lamp project ~30% further.
I believe that "orange-peel" reflectors just make a smoother beam, by "averaging" out shadows/imperfections, and breaking up the filament's own shape and reflection.
But then you lose the extra 30% projection ......
Jahn
how do the reflectors that are partially "orange-peeled" effect the throw/smoothness?
- Pete
Umm, er, well: I'm not sure ......
I assume that's a design compromise to try to achieve both qualities, range and purity. At a guess, the part nearer the lamp would have to be "stochastic" (that is, "random"/orange-peel), and the upper part smooth.
I can't remember which torches have "mixed" reflectors - anyone got one to comment ?
Jahn
I have a "mixed" reflector and there are artifacts, rings and shadows but not to a degree that I say "Yech". Also I keep mine in tight focus so all I get is a hotspot that is "clean".
I very much like my US and it is the first grab when I need to check out a noise in the middle of the night.
Jahn. It's about damn time you come back to the warm fuzzy fold of CPF more often.
Yea I second that Jahn!!! I did not mean brighter I meant longer throw... Both lights put out the same amount of light.
Aw shucks guys
Sunspot, you are so right !! (But then, I always agree with you about everything ... )
On the mixed reflector issue, it seems that you end up with a compromised beam from a compromise design.
Bushman, I was sure that's what you really meant.
(Sorry for going off-topic here)
Jahn
<font size="2" face="Verdana, Arial">I want to go off topic also.
I'm going to try your anodize removal method on a GMG Ultra-Goverment model. The reflector is anodized for crip's sake.
btw, just get up? ;-)
My US has the treads on the outside however I just bought a new one for a guy at work and his reflector is different. They are both two stage but his is shiner at the top than mine is?
