F
frogamic
I want an XM-L light because they're new, efficient and very bright. I currently own the Fenix TK11 and PD31. Here's the new light quiz thing
I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
Less than $150.
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
I don’t care.
5) Emitter/Light source:
XM-L
6) Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
AND
I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
30-150 yards/meters (I live in a very rural area/farm with wide open spaces)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
30-60 minutes (I have plenty of batteries just ready to be changed)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Very Important (Camping, Backpacking, Car Glove-box).
12) Switch Type and location (choose all that apply):
I want a forward clicky (Helpful for momentary activation and signaling).
I want a tail mounted switch (found on the majority of today’s high end lights).
I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
Holster would be nice.
I was thinking of a TK35 but I want to try some different brands and I've been hearing some worrying things about the quality of it.
Less than $150.
3) Format:
I don’t care.
XM-L
6) Manufacturer:
AND
