manappraisal
- Joined
- Sep 12, 2010
- Messages
- 9
Hello:
This is my first posting. I am trying to design an LED lighting array for use for video production in small indoor spaces. I am just getting my feet wet on LED lighting, but from my research I would anticipate the use of 4-6 10 watt emitters powered by a sealed lead acid 12V 7.5A battery.
The light should be diffuse. The idea is to uniformly light small rooms or provide light support for larger rooms that have indirect sunlight through windows.
I would be grateful for some advice on circuit deisgn and emitter selection and requred heat sinking. Do I use resistors or do I need drivers?
My first attempt to light up a 10 watt LED resulted in a burn out in about one minute. Using an online LED calculator a 1 ohm resistor of atleast 4 watts capacity was suggested. I had the LED mounted on a 3 X 6 inch piece of steel which is approx 1/32 inch thick. Thermal paste was used between the LED back plate and the metal.
The LED used was spec'd at 12V forward voltage, 1000ma current. A 1 ohm, 10 watt 10% resistor was used on the positive lead.
Why did I fry the LED, and could recommendations be made on the best approach for getting the most light output using one of these batteries?
Many thanks.
Jeff in Floirida
Many thanks.
Jeff in Floirida
