Yes and no. Yes you can do it, yes it might last longer but that all depends on what kind of light it is, what kind of light is it?
NiMh have less voltage when fully charged then fresh alkenlines that is true, but they also have a flatter discharge curve, meaning that after using regular batteries for only a short time, they'll have lower voltage then NiMh. Maybe another friendly CPF member can post a graph.
I personally don't like to use NiMh in my torches because they have a high self discharge rate and if you discharge them too low is can dammage the battery, but many others use them with no problems. Also, in some cases it's better to use NiMh because of the lower voltage. In some of the home made flashlights around here it's better for the LED to be run at a lower voltage, but that isn't really the case with lights bought at the store.
