Policetacteam
I just received my second M60 from Gene's newer run of the M60, the non-hand engraved units. This newer one that I just received approximately 1 week ago is much different. The build is definitely the same solid construction and excellent heat sinking that we are accustomed to from Malkoff drop-ins. The quality of the light is much different. This production line M60 as compared to my last production line M60 is much warmer than the last, which was considerably much cooler. I really don't care either way in regards to the cooler or warmer. But the hot spot appears very yellow and with a large void. All of my other M60's produce a very solid, very bright hot spot with good spill for room clearing. This particular drop-in does not. I know that with anything in production there can and will be abnormalities. I'm just curious if you all have noticed any changes in quality. This is by no means a slam on Gene because I use his drop-ins and his only! This is just a major difference in appearance from my others. I already sent Gene an e-mail to hopefully get an exchange. I will try to post some pics later.
