AardvarkSagus
Nextorch MyTorch 18650 - Submitted for consideration for the review forum
Hey! You got your computer in my flashlight! The Nextorch MyTorch brings current technology to a new level in portable lighting devices. Is this too much too soon, or just the next step in flashlight evolution?
Meat and Potatoes
You’ve seen me review lights with programmable modes before. You’ve even seen some lights with some pretty impressive programming capabilities, but thus far, I have not yet found a light with a programming interface as complex, yet intuitive as the MyTorch. All the programming for this light is done through a graphical user interface via the Nextorch Nextuner application downloaded on your PC. This program uses a USB interface to download your selected modes to your torch. Inside the Nextuner you have nearly an unlimited number of mode combinations, and even the ability to save your favorite configurations to either share with others through the MyTorch website or merely set aside for later use.
USB Port
Though Nextorch offers a quartet of options for your choice of power source, I had the opportunity to try out the premier 18650 model. This flavor has a couple of options that I don’t believe are included with the other versions, but shares a large number of common features with lower end models. The fit and finish of the MyTorch is absolutely excellent. The anodizing is smooth and completely uniform and thus far it has resisted visible damage quite well in my care (it’s even been baby tested!). Its chrome bezel and tailcap rings are a nice visual touch offering a classy addition to its otherwise understated appearance. The Glow in the dark tailcap switch is far better implemented here than any other I have yet seen. It is nearly flush mounted covering the extremely short throw reverse clicky, but its large contact area makes it a very easy target.
GITD Clicky
Though it is called an 18650, the cell included with this torch is notably larger than any other 18650’s I have yet used. I believe this is owed to a unique contact configuration that allows it to also be charged via the included USB port. I have tried some other 18650’s and they seem to power it just fine, but don’t appear to posses the ability to charge the same way. Conversely, the included cell is actually so large that it doesn’t fit into a single one of my other 18650 capable lights. Combined with its unique contacts it effectively makes this a proprietary power source that can handle standard 18650’s in a pinch. I have no idea whether it is capable of handling the higher voltage of a pair of lithium primary CR123A’s but with this much sophisticated circuitry involved, I am loath to attempt to bring forth the magic blue smoke.
Nextorch 18650
This particular model is equipped with an R5 bin Cree XP-G emitter nestled in a relatively deep lightly stippled reflector. It is capable of producing 200 ANSI FL1 lumens at the top end of the spectrum and is fairly well focused. It’s definitely not an uber-thrower like some lights of similar size, but will hold its own in an outright distance comparison. Thankfully it is graced with the wide corona and bright spillbeam that is typical for this LED. Combined with extremely few artifacts and you have a resulting beam with no distractions and a wide range of usability.
Cree XP-G
Constructive Criticism
With such a heavy emphasis on programming, I am surprised to see a couple of features lacking in the Nextuner application. Each setting in the application offers you the option of a % of total luminance, your choice of strobe frequency, and a “Customize” setting. This customize setting allows you to program a sequence of flashes by delineating how many milliseconds the light will stay on and how many it will stay off. There is no pre-set SOS mode or option for variable brightness in the customize settings. I managed to fashion a relatively decent SOS, but it was something that had to be thought through. I’d love to see future versions of the Nextuner software increase the number of options it offers.
The likely reason behind the lack of brightness selection for the custom modes is that the MyTorch uses a relatively low frequency PWM to accomplish its variability in constant modes. This isn’t something that causes any genuine usage distractions, but to someone sensitive to it as I am, it is readily noticeable. I am wishing that Nextorch would somehow find a way to increase the frequency to a less noticeable level.
One thing that threw me off at first was how this light seemed to have a mode memory not spoken of in any of the literature. It appeared that it was always coming on in the next mode in sequence when I turned the light on. Apparently this was really because of the inordinately long period of time before the light reverts back to its starting mode. My sample took between 15-20 seconds of being off before it came back on in first position. I wish that this could be somewhat shorter, but once I learned what to expect, it was more predictable in behavior.
Conclusions
Being the first mass-market USB programmable light is a huge milestone in and of itself. Doing so with this level of panache takes some real skill. Combine those with a seriously affordable price point and you have more than just a winner, you have a game changer.
Provided for review by the kind folks at Battery Junction.
Meat and Potatoes
USB Port
GITD Clicky
Nextorch 18650
Cree XP-G
Conclusions
