BugLightGeek
Just thought I'd post some info about this 2AA flashlight from Brinkmann since I haven't seen the info anywhere else. It uses Brinkmann's NextStar Xenon bi-pin bulb and has a tailcap switch. The light itself is about half an inch longer than a 2AA mag and the body is about 75% thicker/wider than a 2AA mag.
It has a tighter beam than maglites normally and even has a tighter beam than a maglite using the same NextStar bulb.
[Click here for larger photo]
I beleive it will make a good base for 1, 2 or 3 5mm LED's. Currently, I have one bright blue Nichia LED in one of mine and will be adding more soon. Verrrryyy bright
