Ni-MH battery question.
Chris M.
South Wales, UK
Is there such a thing as 1/2-AA Ni-MH batteries? If so where in the UK can I get some?
The reason I ask is that I recently got a LEDtronics Flashled (with 6 white leds). It uses 3 "N" size alkalines and also has the option of using 2 AAs instead for a much extended run time but at a reduced brightness (it`s only about Infinity brightness with AAs). I find I`m using it quite a lot- it`s brighter than any 1-led keychain lights and compact enough to fit in my pocket- the clip keeps it in position. Usually I forget it`s there unless I kneel down- then it makes its presence known. Anywhere round here in this bit of the world, N-cells are kinda hard to find, so I wanted to try using rechargeables in it instead when the supplied Ns run out, so I wouldn`t have to worry about finding replacements for it any more in the future. Just keep a spare charged set on hand. The best thing I thought of would be 4x 1/2-AA Ni-MH cells as they would have the best capacity/runtime for the size. They would fit exactly in place 2 AAs and deliver about 4.8 volts (is that right- 1.2v per cell?), higher than with 3 Ns but probably fine since the current to the leds is already limited and the extra few tenths of a volt shouldn`t damage them. It would probably be brighter too which is a good thing.
I know 2/3-AAs exist and 3 would fit inside, but they`d deliver less volts than the Ns and hence less current to the leds- and this light is dim enough already so I don`t want to do that. I can also get 1/3-AA, 4 would fit fine with a spacer but the runtime would probably leave a lot to be desired.
What do you think then? Good idea, or don`t 1/2-AA cells exist?
Thanks, I think I`ll try the 1/2-AAs from RS components for now- we buy from them in work so if those in charge are feeling in a good mood I may be able to scavenge some for nothing. I do use my Flashled in work to see the part nos on smt components and the colours on resistors so they may be nice to me if I put it that way
(we have sodium lighting out in the factory unit where the components are kept, and it can be hard to see what colour the stripes are out of the component drawers).
Doug, the reason why I`d prefer 4x 1/2-AAs is to try and make the light brighter than it is now, as well as economical to maintain. It`s current limited (probably resistors) and is probably dimmer than Lightwave 2000 and Eternalight- and they have less leds. I don`t have either yet though so I`m going on what I`ve read. 3 cells would give a lower voltage than the N-cells and it would be dimmer which I don`t really want. I`ll probably try both though and choose one I like, that would be best. It`s a case of brightness over runtime, and my thinking is that I have my Arc for long runtime (and Infinity for even longer runtime).
Chris, If you merely substitute 3>2/3AA, you will be surprised at how good the performance will be. As we all know, rechrg. cell voltages do
not suppress under a considerable load (6LEDs)near as much as those little"N"alk.cells do...
If you decide to use Nimh 2/3AA (600maH), try: www.mcmelectronics.com -part #29-3270
