Well I've been riding around all day long to find a good piece of copper to solder the MaxFlex to and make a thermal transfer to the MagD barrel possible. At the last shop I went to I finally found what I was looking for A piece of copper pipe of 50mm long and outside diameter 37.3mm. The inside diameter of the barrel is 34.2mm so I need to work a little on this pipe to make it fit. Tomorrow I have time to work on it, I think this will be sufficient to draw away 2W of heat from the MaxFlex (when operating at max output in my application).
Here's an image with the MaxFlex and a Luxeon star for size comparison :
This is the last part I needed to start working on my 7xCree R2 Mag modification
Cheers!
Cheers!
