xpitxbullx
I finally received my NightCutter 5CSI UV(375nm). It runs off of 2x123 (Pila 168S was too tight). I don't mind that it is a twisty light since you aren't going to use it for signaling anyways. It does have a momentary spot of the twist right before full on where all you have to do is press on the side of the head to activate momentary. No clip. Comes with a nice breakaway lanyard and a recessed spot for keychain.
First thing I noticed was that this flashlight's 5 LEDs produce a small but powerful UV hotspot. No sidespill so if you want a larger viewing area, stand back further. There was less visible light than my 395nm Inova X5T. Items flouresced brighter with less purple than the X5T. This is by far the best UV flashlight 'for its size'. It's UV level (375nm) is perfect level of UV power vs. cost ($79). This is one awesome light! If anyone is ever thinking of getting a small pocketable UV light, THIS IS IT!
One sad note, though. The only UV light I've found so far that can flouresce a $100 bill strip is my custom made UV slip on filter for my miniHID or Mag85 (my most powerful UV setup). Not even the NightCutter 5CSI could flouresce the strip on a $100. Neither could the UV Inova or the UV Photon Micro.
Still the best pocketable light blended with power (for the money) is the NightCutter. I hope in the future they flood the light out just a tad more for a larger viewing area while up close.
Jeff
Jeff
