Ok. VIP lamps are out. Period. I called two primary U.S. distributors and even Osram. Osram NO LONGER makes ANY VIP lamps without reflectors and they haven't for a long time.
Is this bad news? Well that's what I thought at first. But the answer is no. It's actually very very very great news, because it led me to find this!!!
:twothumbs Ushio UXL-502HS-0 :twothumbs
PN#5000362
This is the Derek Foreal of lamps, "the answer to all your dreams" to quote the movie. This is the Ushio version of the Osram XBO 500 W/RC OFR that I was originally going to work with, but with an improvement. The Ushio version is 1200 hours instead of 200 hours. And, it's actually available. It's pricey, but it is available!
Now we're back to talking 260,000 lm/cm2 average luminance and in a DC lamp to boot! DC gives us better light gathering as well as a much better single point luminance peak instead of the two points with AC! Even if the Maxablaster lamp's average luminance were to match this lamp, the peak luminance of this lamp will be even greater than the Maxablaster lamp's peak luminance because this lamp is a Xenon lamp. This is huge. The new numbers will be simply astounding, and they will be very much underrated when compared to the Maxblaster lamp due to the differences in peak luminance that is not reflected in the estimations.
Also, since we're working with a DC output now, I plan to do away with a DC/AC inverter feeding a full rectifying power supply. I'm planning a specialized power supply that is powered directly by either a 12v battery or external 12v source. This will greatly reduce the component size and weight because no big transformers and filter capacitors will be needed anymore. I would like to just use a current regulating DC/DC converter with a DC igniter module fed directly from the 12v battery or external 12v source.
