Nitecore Concept C2vn - Subcompact High Output Thrower R
vinhnguyen54
  • Factory Link Here
  • Finally a Nitecore R
  • Excellent Focus & Tint
  • Excellent size performance ratio
  • Properly built inside out
  • Full click = ON/OFF, When ON 1/2 Press changes levels
  • Instant Turbo from OFF = Full click & Hold
  • Access Discos from ON = Full lick & Hold to enter, 1/2 press to select
XHP35 HD 6500K: 6400L, 55Kcd, 469m
XHP35 HI 6500K: 5500L, 100Kcd, 633m
$250 Any XHP35 LED you want
vinhnguyen54
Re: Nitecore Concept 2vn - Subcompact High Output Thrower R
That's impressive, Wow!
Handsome as well.
So glad it doesn't have one of those OLED that tends to break. Finally a perfectly made light inside out from Nitecore.
Rasher
Mostly California
Looks interesting!
Waiting to see results for Noctigon M43vn with W1/W2, will pick up the better performing of the two from you.
[h=1][/h]
vinhnguyen54
Looks interesting!
[h=1][/h]
Ok first con. Its slippery.
wimmer21
Kentucky
Impressive! Wish it didn't have a clip though.
wimmer21
Kentucky
Ok cool. I thought it looked fixed. I like it even more now! :)
vinhnguyen54
Its a very good light. LED sit on thick copper that sits on a nice shelf that distribute heat to the body. Everything is very cramp and compact. I dont think there is another smaller 4*18650 light...
drummer132132
Anyone know if there is access to instant low from off? For example, let's say you turn off the light on medium mode can you access the light on its lowest mode even though it was last turned off on medium?
vinhnguyen54
A customer ordered the light with 5000K & 6500K HI and it came out excellent. I actually prefer it most. Very Very good light. Congrats to Nitecore.
vinhnguyen54
Nice concept.., looks good. Can the 4x18650 "power pack".., be readily accessed..., charged externally/cell's changed etc..?
Future batteries upgrade are extremely easy. Just one solder joint to remove the leaf spring tension and the cells pop right out. The light is really just barely big enough to hold 4 cells. Everything is super compact. So glad LEDs sit on a proper shelf too. This suggest the body was likely CNC from a solid block of aluminum making for continously heat sinking.
Newlumen
United States
Thanks skylumen for the giving this light a R. I feel comfortable purchasing this light.. i like the unque square design. c2vn xhp 35 hi 6500k order placed.
