Nitecore Concept C2vn - Subcompact High Output Thrower R
S
SKV89
Does each emitter have its own mcpcb or do they share one mcpcb? If individual, what diameter is the mcpcb?
vinhnguyen54
vinhnguyen54
One large thick Quad MCPCB. I will grab pics when I do a comprehensive VNX3 mod.
vinhnguyen54
vinhnguyen54
Will the VNX3 mod change the performance of this light?
In theory it should boost 5000L to 9000L and 100Kcd upward accordingly. I got more stock coming so I can do all the test. I will likely upgrade the cells capacity with suitable drain handing while I am at it. We will see.
Newlumen
Newlumen
United States
I want a driver vnx and upgrade battery for the nitecore c2vn. Lmk the additional cost.
vinhnguyen54
vinhnguyen54
I will hang on to your order. If I can make exceptional improvements I will update yah.
T
twistedraven
If you think you can run White2s in this host I'ma go ahead and place a custom order.
vinhnguyen54
vinhnguyen54
I have a feeling XHP35 HI driven to 9000L will be the way to go. Anyhow. Just hang tight. :)
S
Sky
up state New York
Can't wait for the new numbers, it is going to be a winner. Will order as soon as new pricing is available.
T
twistedraven
To me 100 watts of power is just too much for this little host to handle. The TN40 driven to the same wattage gets hot in like 30-60 seconds.
4 well driven white2s should only be like half that power at most. Plus I'm a throw guy. :sssh:
Can't wait for new numbers.
vinhnguyen54
vinhnguyen54
Lets just hope I can fit my driver inside. Cross your fingers ;-)
vinhnguyen54
vinhnguyen54
Ok so I tried the White 2 with the reflector over the LEDs outside of the light but I was not impressed so I didn't bother to take it all the way.
With the light apart I was able to boost the original circuit and went from 5500L to 6500L. 100Kcd to 115Kcd. Does seam noticeably brighter.
I am going to check out to see if VNX3 will work not. Mod would be rather complicated as we will have to reconfigure battery configuration, MCPCB configuration, and charging circuitry...Boy not sure if its worth all this for may be 1500-2500L more than the power boost....
T
twistedraven
What kind of numbers are you getting with white2s and white1s with the reflectors outside of the light.
vinhnguyen54
vinhnguyen54
I can't measure it that way. But no point to proceed if the beam and output isn't impressive when paired with this overlapping reflectors.
vinhnguyen54
vinhnguyen54
I must say this light is very well designed. It's as compact as it get. Most nitecores are innovative but this is one of the rare ones that actually completes.
T
twistedraven
Hotspot doesn't get noticeably more intense with the Osram emitters?
Don't see how you could fit a vn driver in there.
vinhnguyen54
vinhnguyen54
The scary part is the mod is irreversible. If I screw up with VNX3 then its a big financial hit.
Similar threads
vinhnguyen54
Replies
6
Views
2K
vinhnguyen54
vinhnguyen54
vinhnguyen54
Replies
136
Views
29K
OnlyownEnergizer250lumen
O
vinhnguyen54
Replies
611
Views
114K
brighterthanthesun
B
vinhnguyen54
Replies
24
Views
5K
b8llzblue
B
