another ~3 month user report in.
Mine D10 worked well straight out of the box so I never relubed it at the time like many did. I did add writeright to the lens to tame the cree, I don't mind the loss in throw.
For the first months of ownership I would often not get the double clicks fast enough and just though it was my slow hands and the UI required response time was a bit to fast. Well just for kicks the other day I took it apart and relubed it with "
Dupont 100% Teflon Drivetrain Lubricant". Wow! The improvement in the switch action was spectacular. Since the button rebounds faster it is much easier for me to get the double-clicks fast enough for the UI.
The link above is to some old catalog specs, I believe it was discontinued years ago. The "drivetrain" version is thicker than an oil but thinner than a grease. I use the grease version on threads and O-rings. But the thinner "Drivetrain" is great for the Piston!
I also did a brightness comparison of low and high to various levels on my new RA clicky. The Ra is supposed to be calibrated OTF lumens.
Using Ra levels as comparison:
D10 on max = about 90 lm with eneloop
D10 on lowest = about 0.7 lm
