You might want to take a look at the Zebralight SC51 - it should be out of preorder and in actual circulation now. It currently has the highest output on 1xAA battery, it has a great clip and it has a side switch (and Zebralight switches are the nice electronic ones - feel like your car radio buttons). If I didn't already have my HDS EDC (will never buy another pocket light after buying this one), that's the light I'd be eyeing up. Maybe wait for the reviews.
It drains the battery very slightly when you use the tail switch to 'turn it off'. In actual fact, it doesn't turn off completely. This is done to preserve the brightness setting you were using when shut off.
Not seen this before. As mentioned above the D10 remembers the last setting even with the battery out. If yours is not doing this, it's defective and should again be returned for replacement.When turned back on, you're back to full power again.
Don't worry - it doesn't. I keep one on my bedstand for several months at a time (only used occasionally) and it fires up every time no probs.... I didnt know that it drained the battery.
There was a batch made about 18 months ago which did have battery drain issues due to a faulty component - perhaps you have one of those, in which case, you should be entitled to a replacement.
.... If yours is not doing this, it's defective and should again be returned for replacement.
But if you bought it from the marketplace, do you ask the cpf user for a replacement or ask NiteCore? :candle:
I also think the 4 sevens quark 123 would be more nice.I have many Nite Cores and have many Quarks....My opinion; Stick with 4 sevens Quarks.
1.Dependable
2. More options (low low ect.)
3. Great service and warranty.
But This Is Just My 2 Cents.
But if you bought it from the marketplace, do you ask the cpf user for a replacement or ask NiteCore? :candle:The old buyer beware, not sure but if it's a warranty issue you may not need a receipt. In which case 1rst or third owner if it's a factory defect I would hope that you'd be okay.
