NITECORE EC4 Review (2x18650,1050Lm,XM-L2)
FlashLion
Europe
The EC4 is a new flashlight from Nitecore's Explorer series lights.
It comes with new ideas for body design and manufacturing. The EC4 is the first flashlight which is manufactured by Die-Cast process,allowing higher standards for density of the aluminum body and heat transfer efficiency.
According to Nitecore the new EC4 is-
200% the strength of an ordinary flashlight that consists of 3 separate parts;
The strength of the Die-cast aluminum body is allowing smaller dimension of the flashlight,respectively less weight.
Better cooling performance,thanks to the Uni-body aluminum construction.
Nitecore EC4 is powered by two 18650 batteries,side by side,electrically connected in series(or 4 CR123A).
For a better functionality,the EC4 is equipped with a standard 1/4" tripod mount point.
The big ring is actually the screw which does lock the tailcap in place.
Another novelty is the external finish of the aluminum.
Only the tail-cap screw is anodized.The rest of the body is Stoving-Varnish treated.
The surface is black/dark grey color,noticeably matte finish.
According to Nitecore,this type finish has great parameters for wear,corrosion,chemical resistance,impact resistance and hardness.
I can't comment on these points,because I don't do this type of tests.
18 cooling fins (nine on each side) ensure high heat transfer from the LED to the ambient air.
Unlike any other flashlight,here all of the cooling fins are positioned alongside the head.
Comfortable grip. There's no much grooves,or knurling,but thanks to its shape with flattened sides,the EC4 is easy to stably hold in the hand.
Size comparison-Left to Right
Nitecore EC4, Nitecore SRT6, ThruNite Lynx, Olight M22, Klarus XT11(2014)
The EC4 and the M22 have identical head diameter.
(Hint-the M22's diffuser fits perfectly on the EC4's head)
Weight with batteries:
Nitecore EC4 260 gr
Nitecore SRT6 197 gr
ThruNite Lynx 257 gr
Olight M22 193 gr
Klarus XT11 186 gr
Standard for Nitecore carton box.
All important info printed on it.
Really interesting and appreciated is the sectional view of the flashlight.
Great chance to learn what parts contains the EC4 and how they are assembled.
Accessories- good holster and lanyard.
You will find also well written user manual and warranty card.
The holster is big enough for the EC4.There is a velcro tape on the back.
The flashlight can be inserted in both directions(head or tail down).
Matte stainless steel bezel.Not crenelated,which makes it more friendly for pocket carrying.
Ultra clear glass lens-toughened mineral glass with anti-reflective coating for good light transmittance.
Cree XM-L2 U2 LED. Perfectly centered.
A specially designed aluminum reflector with smooth reflective surface.
The glass lens is very clean and transparent.
Anti-reflective coating in purple color.
Lets take a closer look at the Dual switch.
Two electronic push buttons with a silicon cap,separated in two zones by a small bridge.
The button with the four lines is for mode selecting. The other is for ON/OFF,as both of the switches have additional,hidden functions-directly activating Turbo,UltraLow and Strobe mode.
I am impressed of the user interface and operation with the dual switch.
This is the best user interface I've tested and suits my way of using the flashlight,just perfectly.
Five brightness levels,plus 3 flashing modes.
Clicking the ON/OFF button activates/deactivates the light. Press and hold it for a second to activate Moonlight mode,directly from Off.
If you press and hold it,while the light is ON,this will activate the Blue indicator light under the button.Will turn the light Off,as well.
There is no memory for the indicator light. If you need the indicator light for easier locating the flashlight,you have to activate it manually,every time.
Click on the right picture to see the full user manual that comes with the flashlight.
The second switch(with the four lines) is for mode selecting.
Press it to select among UltraLow-Low-Mid-High-Turbo modes,while the light is ON.
Press and hold it to activate Strobe mode. Press and hold again to activate Beacon and again to activate SOS mode.
Short press will return the constant light mode.
If you press and hold the switch for a second,while the light is OFF,this will activate Turbo mode directly.
Double click(the mode switch) starts Strobe mode immediately from OFF.
There is memory for the last used mode,except the 3 flashing modes.
The mode memory is extremely quick and does not require any special timings for ON/OFF to make it work.
If you leave it on High mode,it will start on High mode,no matter how quickly will turn it ON/OFF.
The UI is quite easy to remember and use. I did not find any trouble using it in real life situations.
Quick and accurate response from the driver.
There is one more function of the mode switch. If you press it briefly,while the light is OFF,the blue indicator light will show the level of the batteries by simple blinking.
Three flashes indicates battery voltage over 50%.
Two indicates battery voltage below 50%.
One flash means the batteries need to be replaced.
There is also switch locking option. Press and hold both switches together,for over one second to turn the light Off and lock the switches.
To unlock,press and hold both switches again,for over one second.
I feel the switches well in my hand.Easy access to both switches.
My fingers are thin,though and in my opinion people with bigger fingers may find the buttons smaller than needed and also may have to press them with a nail. The buttons are almost on the same level with the aluminum around them.
The separating bridge works well for me and I am pressing the right switch every time when I have to.
A closer look.
A closer look at the Stoving-varnish finish and the grooves forming squares.
The cooling fins. You can see how smooth are all edges thanks to the die-cast process of making the flashlight's body.
All edges at the tail are very smooth,well rounded,too.
Good care to detail.
A thick rubber(probably silicone) gasket ensures excellent water-resistant sealing.
The EC4 can tail-stand not only on a table.It can be quite stable on different surfaces.
There is no protruding switch at the tail.
The thick ring at the tail end is a big screw. You can see the threads at both sides of the battery tube.
There are threads only on the surface between the batteries.
Two protected batteries fit pretty well in length and width.
No battery carrier.
Great care to the electric part of the flashlight.
Each of the two springs is doubled by a second,smaller spring.This ensures higher efficiency thanks to less losses in the springs(less resistance,easier current flow).
The driver board.
There is a physical reverse polarity protection. Flat top batteries can't be used directly.
There are stickers showing the right direction for inserting the batteries.
A very close look at the thick sealing rubber gasket.
Smooth aluminum reflector. Cree XM-L2 U2 LED.
1050 Lumens max output. 26000cd peak beam intensity.(30 000cd,measured by me at 3 meters)
The light from the EC4 is clean Cool white light,with no visible greenish or bluish tint.
The beam profile consists clearly defined hotspot and corona with good smooth spill.
As almost any actual flashlight,a smooth reflector is used for better focusing the light,aiming maximum distance of throw.
This sacrifices some of the beam smoothness,but beam is still quite good in normal use(not on a white wall).
Run-time Performance
Thanks to the dual battery design resulting in high total voltage, Nitecore EC4 performs impressively well.
Two 18650 batteries in series(or 4xCR123A) provides enough energy for stable output.
The output on all modes is constant,even on Turbo mode.
Unlike the single cell flashlights,the EC4's Turbo mode comes on the same output after every restart.
I did a few tests with different batteries.
I tested the output on Turbo mode,while the flashlight was cooled by small 8cm fan and also without cooling fan.
Room temperature ~25 degrees Celsius.
Three tests-With the cooling Fan on max airflow,with the Fan on very Low rpm,with no cooling.
According to Nitecore,the EC4 features Advance Temperature Regulation.
Unfortunately,I did not manage to activate it,or at least I don't see it,as I expected to be.
With maximum air cooling(simulating using the flashlight at places with cold climate,or in the cold seasons),the EC4 performs impressively.
The output starts from 1140 Lumens. 30 seconds later the output is 1067 Lumens.
The EC4 is maintaining just over 1000 lumens,through the whole battery discharge.
Checking the flashlight for overheating,I was impressed to find that the EC4 stays cool,even at this high output.
The second test with minimum air cooling,shows similar performance.The same time of discharge 98 minutes,nearly constant output.
Just 10 or 20 lumens less at some moments,due to more heating.
During the test the EC4 was warm,but not too hot.
The third test was especially to test the ATR temperature control. No any kind of cooling was used. Static flashlight pointed at the light sphere.
I expected some kind of gradual step down as seen in the headlamp HC50,but here such step down does not exist.
The flashlight got very hot and I stopped the test after 10 minutes to prevent overheating. Lumen output 975 lumens at the tenth minute.
The flashlight may resist the heat,but it's recommended to keep the temperature of the batteries in normal range.
Batteries used in the tests- Keeppower 3100mAh,protected.
(Low voltage protection tests- Keeppower 3100mAh, Sanyo 2600mAh protected)
Only the first 15 minutes
My lumen measurements:
Fully charged Keeppower 3100 batteries.No cooling.
30 seconds after activation.
Turbo 1050 Lm
High 600 Lm
Mid 280 Lm
Low 114 Lm
UltraLow 1 Lm
Pretty well spaced brightness levels. A 50 lumen mode would be also useful,but one more mode may overload the UI.
I don't detect any sign of PWM on any of the modes,with the oscilloscope I use.
But,after using the flashlight for some more time,I can detect some noise(not sound) in the light on UltraLow and Low when watching a PC cooling fan. I can't confirm this is a PWM,because the oscilloscope,just doesn't see it. It's definitely not the usual pwm,maybe more advanced one,combining multiple signals... I don't have enough knowledge in electronics,so better not trying to guess...
The flickering should not be visible in normal use.
The Nitecore EC4 features also a Low voltage protection. To be sure it will kick in on time,the two batteries must have identical voltage.
If not,the low voltage protection of the battery with the lower voltage will kick in,before the EC4's LV protection.
In my tests,the EC4 did not show any indication by the blue indicator light,or by flashing main light,that the batteries are empty.
The low voltage protection turned off the light without any warning.
I did not test with unprotected batteries. I prefer to use protected batteries,for a little more safety, also recommend using protected batteries,especially in this flashlight.
Thanks to the efficient driver electronics and dual battery power source,the current draw on Turbo mode is just 1,7 Amp. High drain batteries are not needed for a good output. Any battery with a quality cell should be fine.
Nitecore EC4 has only electronic switches.There is no physical switch to fully disconnect the power to the driver circuit. When OFF,the flashlight is actually in Standby mode,which takes ~350µA from the batteries. This value is much higher than the value in all other flashlights I've tested. If you plan not to use the EC4 for very long time,it's recommended to take out the batteries,preventing over-discharging. Lock out the tailcap is not possible.
Beam shots
1 meter, 1/20sec
1 meter, 1/250sec
5 meters
1/6sec
5 meters
1/50sec
The Nitecore EC4 covers most of my expectations.
There are only a few weak points that could be improved in future models.
I found the EC4 quite comfortable in use,great constant output,good beam,fantastic user interface.
All these things makes the EC4 one of the best flashlights I have tested/reviewed and it definitely will become one of my most used lights.
The tripod mount thread makes it a good choice for a camping light,home work,or any other repair work.
Strong points- Build quality;Fresh ideas in the design; Tail-stand possible; Tripod mount option; Great fit in hand; High maximum brightness; Constant output on all modes;Well spaced modes; Great user interface; Quick access to Turbo,UltraLow and Strobe; Instant mode memory; High efficient driver; Deep smooth reflector results in great distance of throw; Impressively well maintaining the heat,while using on Turbo mode in cool ambient temperature;
Weak points-The dual switch may be uncomfortable for people with big fingers(depending on the way of pressing it); No output step down to prevent overheating; No indicator warning while the batteries are empty; Very high Standby current consumption; No tailcap lock-out option;The finish just does not look as good as quality anodization;
Thanks for reading!
Hope you found my review quite informative and helpful.
If you like my work,please post a comment below.Your feedback is always highly appreciated.
- Thanks to Nitecore for providing the EC4 for test and review! -
Reserved for corrections and additional info.
markr6
Thanks for the review. ~350µA standby :( I'm really waiting for the EC4S, and can only assume it's just as bad. I wonder how much is consumed when locked out via the switches? I see the manual says it's functional for over 12 months in this state. I have their TM16 coming which says only 6 months! That worries me, but I'll just have to try and see.
Overclocker
Philippines
we don't need a 2x 18650 that puts out 1000 lumens. what we need is a 2x AA die-cast side-by-side that's really compact
holygeez03
That would be interesting to see what could be pulled off with 2xAA and modern tech.
FlashLion
Europe
What I can measure is still 350µA after electronic lock.
LessDark
Norway
Thanks for the great review. It looks like a great sturdy light, though I think the star will be the MT-G2 version.
A bit worrying if the overheating issue remains in the coming version as well, as I assume the bigger LED will produce a lot more heat...
KITROBASKIN
New Mexico, USA
Perhaps you can talk with NiteCore, and ask about the temperature compensation experience you had with no fan cooling. Was it not functioning or do you think it is set for too high a temperature?
Can you elaborate why you think the finish does not look as nice as an anodized finish?
Great Review, great photos, slick GIF's. Thanks aplenty for showing the gasket.
FlashLion
Europe
Thank you all for the comments!
Hopefully,they will make happy also the AA battery users and will release an AA version of this model in the future.
Thanks KITROBASKIN for commenting!
I already contacted Nitecore,but they can't give me high detailed information. The info is just-the EC4's driver will regulate the output depending on the temperature.
I suspect,that the temperature control is set to trigger at higher temperature than I expect. In my opinion the flashlight was quite hot after 10 minutes and as I wrote in the review,I don't like to heat Li-Ion batteries too much,no matter how high quality they are(this will shorten their life).
The finish on my sample has some spots/zones,that are not so matte as the rest of the finish(not sure,if my sample is a test sample,already used,or a new regular one).
olemil
Michigan
Great review and thank you!! Very tempted to try one of these, not that I really need another light sitting on the shelf :banghead:. The switch looks a lot like the EA41 which I already have and love by the way. Only thing that I may have a concern about is the partial threads in the body for the tailcap. I'm sure they will be fine for the life of the light but just my concern. Guess it would be worth a try especially since I have 4 brand new 3400mah Orbtronics sitting in my flashlight supply drawer and GG has 20% off this weekend on nitecore. :thumbsup:
zs&tas
UK
So nitecore go on about the die cast and efficiency of heat transfer and the light remains comfortable, but it actually gets really hot ? Dont get me wrong I love the light and am waiting for the s version I really want. Just annoys me thats all !
The only down side I can see is the lack of full tail threads, how easy is it to get the tail threads lined up and spining? Any difficulties ?
:D best review and pics :twothumbs:twothumbs:twothumbs
photonmaster
Banned
Interesting light. Good to see some genuinely new ideas. My concern would be the silicone switch cover, those often end up burst over time. Tempting light though, looks good.
Fantastic review, thanks very much.
FlashLion
Europe
Thanks for the comments!
Thanks
The advantage of the Die-Cast aluminum is mostly the strength of the body,because it's a whole part without mechanical connection at the head,etc.
I also expected some trouble,but I did not find any,while screwing/unscrewing the tailcap. The side plates with the Nitecore logo have the purpose to keep the tailcap in line,while attaching.
The better heat transfer means,that the heat will disperse throughout the body faster,keeping the LED a little cooler. Thanks to the unibody construction,the heat will not stay mostly in the head.The battery tube and tail will get also part of the heat faster,allowing lower temperature at the head.This means of course,that the tail end will be warmer.
The EC4 is still a compact flashlight and don't have enough mass to manage all the heat from a 1000 lumen output,continuously in warm ambient temperature,without cooling it(without moving it,so air can flow through the cooling fins,or just used in cold weather).
Now,the manufacturer decides,when to come the thermal or timed output step-down.
If the flashlight gets too hot and a step down is not visible,I recommend switching to a lower output.
Thanks for reading!
The switch cover is fairly soft on touch.I don't know what is the thickness of the cover.Pressing it with nails,may be a bad idea in long term of use.
WarRaven
Edmonton, Alberta
I would have thought die casting allowed for shapes not easily milled and offer poor thermal conductivity due to impurities of said material.
It certainly is not stronger then milled.
Does anyone have any information of its heat transfer capability beyond my speculation?
FlashLion
Europe
If the aluminum is cast under high pressure,it will have better density and higher strength(high pressure is the key word).
If the element is milled from a die-cast aluminum,may not have difference...
FlashLion
Europe
I am not very familiar with machining,manufacturing aluminum flashlights or any other products,so I use the provided technical information about the product.
We can't give a clear answer about the EC4 specifications,as long as we can test and compare it to other products.
EDIT
Rereading again the whole information on the Nitecore's website,they really not said anywhere that the die-cast aluminum is stronger. Actually the regular aluminum flashlight may be machined of the same die-cast processed aluminum.
The strength comes from the unibody construction,which allows less mechanical connections and making the body at once.
Corrected one of my previous posts,about the threads.
Several quotes from their website.
"A seamless structure means that heat generated by the working LED is delivered evenly and rapidly to the overall surface."
"Eliminates redundant elements like battery compartment and fasteners between the head and the body."
"Test results showed that this novel model has 200% the strength of an ordinary flashlight that consists of 3 separate parts."
"It is a casting method by injecting molten aluminum under high pressure into mold cavity, which involves no separate parts welded or fastened together."
