I have an early body and a later one. The early has a metal flat washer, while the later has a plastic one with a raised portion around the center hole. The raised portion goes toward the boot. Try it without the O-ring.
Has anyone tried SureFire F series filters on the NEX? I'm wondering if they would fit very well...
I can confirm that F04 fits NEX quite nicely.![]()
This happens to me occasionally when I swap the batteries. Usually taking the battery out and putting it back in a couple of times will fix things and then it works OK until the next battery change.After I tried it again, it was only going on when I clicked momentary on. When I clicked it fully in high mode, the light would turn off totally. It was OK in variable mode.
Lastly, does anybody else have a delay of about half a second (maybe even closer to a full second) between switching modes? For a tactical light that's really, really bad. I've also noticed that if I turn off the light in the user-selected mode (which is usually programmed to low power for me), twist the light to be in high power mode, then turn it on, it starts in low power then after a half second delay it will go into high power mode (or strobe).
Just got mine delivered today (E3 R2 model) and dropped in an AW R123 to test it in the dark. Pretty decent for such a small light, but I must admit I was hoping for more... I atribute it to how I'm still new to high end lights, and more used to incandescent lights. A 60 lumen Surefire P60 still looks brighter than a 220 lumen LED to me for some reason...
Some comments to add to Selfbuilt's review (hope you don't mind).
-They changed the packaging. It's no longer a nice foam padded box with latch, but a regular cardboard box with clear plastic window (similar to how Surefire sells theirs).
-They now only include 1 extra clicky instead of two (and two o-rings and an allen wrench).
-The ring which holds on the rubber part of the switch is chrome instead of black, and mine sticks out so I can see the threads on it a little bit (and it won't screw in any farther).
-When I tightened the pocket clip (which was the smallest bit loose) the lock washers underneath separated so they only close maybe 300 degrees, instead of a good 350 like normal, and I've never seen lock washers separate like that (which makes me want to get some locktite on those screws).
-The color of the anodozing is a slightly lighter gray on the head, versus the bezel and the rest of the body.
