NITECORE HC50 565 Lm Headlamp REVIEW
FlashLion
Europe
Hello.
This is the first headlamp from Nitecore. Clean and practical design.Rationally projected form,entirely of aluminum.
Clear looking shape at first look,but there are a few things that are well made and help for using the light in different ways.
A wide selection of well spaced brightness modes plus secondary red light. Modes Ultra Low(1 Lm)-Low(35 Lm)-Mid(170 Lm)-High(350 Lm)-Turbo(565 Lm).
As expected from Nitecore the overall quality is quite high.
The whole construction is durable and made in highest standard. All metal-you don't have to worry for impact resistance and heat dissipation.
Nitecore HC50 comes in a nice cardboard box. In the box you will find also-Headband(of course),spare O-rings,user manual.
Technical specifications (from the User manual)
Purpose-designed for hiking, climbing, camping and general outdoor
recreation
· All metal high-performance dual-beam headlamp
· Aluminum “unibody” construction is highly rugged and provides
excellent cooling performance
· Utilizes a premium CREE XM-L2 (T6) LED
· Powered by a single 18650 lithium-ion battery for up to 565 lumens of
output
· High-efficiency circuit provides up to 400 hours of runtime
· A custom catoptrics-based system produces an extremely wide 100°
beam angle
· Light housing provides 90° vertical movement to eliminate illumination
dead-zones
· Direct access to red light mode with a runtime of up to 145 hours
· Innovative single button two-stage switch is remarkably user-friendly
(patented)
· Ten rapidly switchable brightness modes to select from
· Integrated red/green power indicator light displays remaining battery
power (patented)
· Power indicator secondary function displays battery voltage accurate to
0.1V
· Integrated temperature sensor and intelligent temperature control
ensure stable and safe use
· High-efficiency regulation circuit provides unwavering output
· Toughened ultra-clear mineral glass with anti-reflective coating
· Constructed from aero-grade aluminum alloy
· Rugged HAIII military grade hard-anodized
· Comfortable chafe-free and breathable nylon headband
· Waterproof in accordance with IPX-8 (two meters submersible)
· Impact resistant to 1.5 meters
· Tail stand capability
Battery Options
1x18650 (recommended) (button top)
2xCR123 (recommended)
2xRCR123 (protected 16340/RCR are too long)
Length: 86mm (3.39”)
Diameter: 32mm (1.26”)
Weight : 130g (4.59oz)(without battery)
Black,not too matt (a little glossy) finish.Excellent HA III hard anodizing,all over the body.
There are cooling fins at the front of the lamp,two red LEDs and 11mm(diameter) smooth reflector.
Clean,white labels.
The right side wall is completely flat and allows stable "tail" standing.The other(left side)with the switch also allows side standing due to the recessed switch.
The possibility of accidentally light activation is minimal.
The caps on both sides have form that provides the needed grip when removing the battery tube cap and most important-the headlamp can stay on table stably,pointed at various directions.This makes it useful not only as a headlamp.Can be used as a work light or emergency room light,etc.
The light weights 130 grams,including headband. Sounds a little too heavy,but actually there's nothing in more.The aluminum is just the right thickness and there's nothing excessive in the design. For powerful 18650 flashlight,this weight is just needed for good heat dissipation.
As I always expect from a brand like Nitecore,build quality is excellent. There's no even a single sharp edge.This is a big plus,because this is a headlamp and usually we don't see it when we use it(touch it).
Even the cooling fins have very smooth edges.Actually the smoothest I ever seen.
The headband is very good quality.Good size with enough length for different size heads.
The light holder is made of soft,elastic rubber,very nice to touch.
Attaching and detaching the light from the holder is not too hard to do and doesn't take too much time.Even that the lamp stays quite stably in the holder.
Breathable nylon headband.
The coupling rings are made of plastic.
The headlamp stays very stable and comfortable on my head.Everything is in one place.No separate batteries to worry about.
Size
In my medium size hand.
I don't have other headlamps with similar quality,which worth it to show here and to compare their brightness and quality of light,so I will compare Nitecore HC50 to quality EDC flashlights.
Protected batteries with high capacity fit well in the tube.
Slightly greased O-ring for water-sealing.
Perfectly made rectangular-cut threads.Anodized for maximum wear resistance.Very smooth screwing.
Check out again the cooling fins-how smooth edges they have.What a care to detail.Excellent job!:thumbsup:
The battery is placed not in the center of the tube and this requires rotating connection board.Actually when you spin the cap,the board is locked by the pin you see in the picture.The negative contact spring stays always on its place-over the negative battery end.
Lock out possible.
Battery is positioned at the back side of the headlamp body.This will protect it from too much heating.
Reverse polarity protection for the battery.Flat top batteries don't work.
Toughened ultra-clear mineral glass with anti-reflective coating.
Purple anti-reflective coating.
As a true headlamp,HC50 is made to provide to the user very wide beam,useful nearly everywhere.Very suitable for medium and close range illuminating.
Small and shallow reflector for optimal beam angle of 100 degrees.
Bigger reflector is not required here and thanks to the small size is saved space,allowing more compact body.
There are two 5mm red LEDs on both sides. Very useful low brightness for use in full darkness or for signaling.
The LED installed here is Cree XM-L2 T6,cool white. It gives beautiful clean white light. No greenish or yellowish tint.
Maximum brightness 565 lumens. Really good amount of light from a headlamp.
Peak beam intensity 1820 cd.
Using HC50 is easy and convenient.All modes are well spaced. The highest mode of 565 Lumens gives pretty bright light.
It's great to have low mode of 1 lumen in headlamp.Doesn't affect night vision and will not blind your friends at close distance.Don't forget and the great runtime.
There are 5 constant lighting modes+Slow flash,SOS and Beacon for the white light and 2 modes for the red light- constant and flashing.
Nitecore HC50 utilizes a two stage switch,something like an 'electronic' momentary switch and clicky switch in one place.
The switch is easy to operate with one hand.Easy to turn ON/OFF and change mode. Activating the first or second switch depends on the depth the switch is pressed.
Light press activates the first,mode changing switch.Full press(click) activates the light.
Fully press within a second to activate the last used white light mode.
Fully press(click)and hold for more than a second to activate the red light.
Mode changing is possible by short light press(without click).
For access to the hidden flashing modes just turn the light Off and ON quickly.
HC50 has memory for the last used mode which applies only for the constant white light.
I had a little problem with the switch in the beginning.When I wanted to turn it OFF,I changed firstly the mode.This happens because pressing the On/Off switch is possible after pressing the mode switch.If you press it too slowly,the light will change its mode firstly. Would be good if there was a 0,5sec signal delay on the switch for mode changing.
Turbo 565 Lumens / 1h 15min
High 350 Lumens / 2h 45min
Mid 170 Lumens / 6h 15min
Low 35 Lumens / 32h
Ultra Low 1 Lumen / 400h
Red Light 1,2 Lumens
All data by Nitecore using 2600mAh battery.
Current draw(at the battery)
My measurements
I turbo=1,9A
I high=960mA
I Mid=370mA
I low=73,5mA
I ultra low=7,1mA
I red=12,8mA
Nitecore HC50 uses a high efficient constant current driver with integrated temperature sensor.
Intelligent temperature control maintain the light in optimum condition,decreasing the brightness(current) when the light becomes too hot.
This feature makes the headlamp very safe for using for long periods of time on highest mode with no worrying about how hot it is and will it be damaged and of course this is protection for the user.
To test the temperature controlling I did two runtime tests.First was for ~130 minutes.I used a cooling fan to see how will be the light if the headlamp is used outdoor for biking,walking or hiking,where the air goes through the cooling fins and cool down the whole headlamp.
The second test was without cooling.I tested it for 20 minutes,just to see the moment of the first step down.
Ambient temperature on both tests 21C.
When the temperature reaches 55C, HC50 automatically reduces the output.When the temperature drops below 55C the light restores its output.
Brightness decreasing is slow,gradual and hard to notice it by eyes.
Battery Keeppower 3400 mAh.
U start=4,2V U end=3,2V
When the light is well cooled,it doesn't get hot and keeps its output pretty constant for about 16,5 minutes on Turbo! You can't get this from much bigger flashlights.
Without cooling HC50 gets hot and decreases its output at the 5th minute. I stopped it after 20 minutes work and it was uncomfortably hot at the top,near the Nitecore laser label.
This graph shows only the first 20 minutes,just to compare the maximum time before step down.
I used Keeppower 3400mAh batteries for the tests.
Nitecore HC50 has one more unique feature.Green and Red illumination under the switch boot. These lights have two purposes-indicating the battery voltage and low voltage warning.
Each time when the light is turned on,the red/green light will show the battery status.
If the battery capacity is over 50% green light will illuminate the switch for 2 seconds.
When the power level is under 50% the switch will glow for 2 seconds in red color.
Every time when the battery is replaced the green light will show the battery voltage by flashing.
For battery with voltage 4,2V will blink 4 times,then short pause and 2 more blinks. 0,1V accuracy.
(Can be seen in my video)
These two features are very helpful and work pretty well. It is really good to see the voltage status when inserting a new battery.Quite useful to see the voltage when you are on camping,etc. and don't carry a voltmeter with you.
It's nice to see features like this in headlamps and flashlights that we rely on.
But...it has its price of course.
The battery status is displayed each time when the negative battery pole is disconnected and back connected.No need to press the switch.
This means that there are electronic components under power,no matter the switch is on or off. The "standby" current draw is about ~160uA.
If you don't want to lose this power you can easily lock out the battery cap.
HC50 is equipped with a smooth reflector and due to that the beam is not fully floody smooth.OP reflector would be also a good choice here.The smooth reflector is good in situations requiring more throw.
The dual red light gives good beam-suitable to do something simple in the dark,reading,etc..Color rendering is very limited,but for tasks like finding my camera in the dark and adjusting it,the red light is quite enough.
These photos are with different shutter speed!
White wall.
Beamshots
1meter,white wall, 1/20sec, WB cloudy
Other flashlights(not headlamps)
1meter ,white wall, 1/250sec ,WB cloudy
Other flashlights
5 meters, 1/6 sec
Outdoor beamshots
Foggy weather.
The tree in the center is 35~40meters away.
Just for reference to see how much is the moisture in the air.:)
Thanks for Reading!
Hope my review was helpful for you.
This review is part of the Nitecore HC50 global testing campaign.Thanks to Nitecore for providing HC50 for review!
roberta
Downunder
Re: NITECORE HC50 565 Lm Headlamp REVIEW IN PROGRESS
Good Day FlashLion, :)
Great review.... :thumbsup:
Thank You Very Much,
Roberta :devil:
ChrisGarrett
Miami, Florida
Nice review, nice HL.
Would be nice if they allowed it to run up to 6v, so 2xCR123s could be used in a pinch. My ZL SC600 runs on a 18650 only and that kind of costs us some flexibility.
Chris
FlashLion
Europe
Chris
Thanks.
I see in the user manual that the HC50 is compatible with 2x RCR123A :thumbsup:
ChrisGarrett
Miami, Florida
Thanks.
That's even better, although I think that running a single 18650, either naked, or protected, is the better option, rather than running two RCR123/16340s.
Chris
RGB_LED
North of 43
FlashLion, thanks for a great review. I especially appreciated your comments about the minor issue with turning off light / mode-switching, your beamshots ar also very useful. Also, your testing re: step-down with / without cooling. I am tempted to pick-up this NiteCore over the ZL 18650 headlamps. Good job.:thumbsup:
Overclocker
Philippines
wow jaggies! and falls out of regulation very early.
this is how thermal control and regulation should be done:
but it's ok the nitecore is a cheaper light :D
FlashLion
Europe
It's too hard to compare these graphs. The batteries used for the tests are probably totally different.Sanyo 18650 has different discharge curve compared to Panasonic.The light output is also important and as well I can see,the SC600 makes bigger step down after 5 minutes Vs 16,5 on the Nitecore HC50.
Usually,current drivers specified for using voltage in small variations(1x18650),regulate the output better.
Overclocker
Philippines
before anything i just wanna say your pictures are OUTSTANDING!
it's ok we really cannot expect the nitecore to have a sophisticated thermal control as the zebralight. it is a cheaper light after all
but no, the zebralight uses a buck/boost driver so it really doesn't care about the discharge curve of the cell. notice the FLATNESS until it steps down to med.
don't forget the sc600/h600 put out over 1000 lumens so even if they step down 40% they're still brighter than HC50 :D at selfbuilt's room temperature the stepdown is just around 25%
i just find it disconcerting that the HC50 falls out of regulation so quickly considering that it isn't driven very hard
marcinkov
Bulgaria
Excellent review Flashlion, you prove me that you are the best, greetings from Bulgaria.
Kabible
Lake Arrowhead, So Kal
Very thorough review. I got one a few days ago mostly for automotive work. Used it last night to walk the dog. I live in a mountain community so there's no street lights. This headlamp illuminates much farther out than depicted in your photos. Probably due to the dry air here. Quite pleased so far.
FlashLion
Europe
Thank you marcinkov :thumbsup: I am happy you like my reviews.
Nice review. Thanks :)
Thanks
Thanks!
My camera really isn't so good at night photos.I took the photos near by river and there was very foggy.The settings on all photos are the same.
ven
Manchester UK
Fantastic review ,awesome pics and info,this is at top of list for a head torch:) ,many thanks for review.
whc
Copenhagen, Denmark
Thanks for this great review, waiting for mine to arrive, going to replace my Princeton tec EOS, so can only be better :)
Sendt fra min SM-P605 med Tapatalk 4
Mr. Tone
Illinois
Great review, I am impressed. Your pictures are very nice and clear. The headlamp seems really nice, too.
