Nitecore Mt2C changing mod by hitting the tailcap.
spsurfer
New member
Hello,
I own a Nitecore Mt2C wich I like very much!
But I noticed, that the modus will change if I hit the light or tailcap with my hand.
The light is not in guarantee any more, even if the problem occures about half a year before.
My distributor told me to tighten the switch from the inside, but it's allready really tight.
Is there a solution without buying a new tailcap?
Kind regards
surfer
NitecoreStore
Well-known member
Manufacturer
Texas
A loosen plate inside the tail cap could cause the problem but it might not be the only factor.
The light should still be under 5 year warranty.
We recommend to write to the factory technical support directly at [email protected]. They might offer your more insights and which closest place you can get it fixed.
300Z
Member
Thanks!
I'll contact the technical support!
Regards
surfer
I’m sorry I know this is an old thread but were you able to get your mt2c fixed?
I have been having the same problem with mine.
