The title pretty much says it all.. I have an old P18 that I hadn't ever really carried much, but do to a change in circumstances, has entered the daily rotation. The P18 is the die cast kinda oval light that has the auxiliary red led separate and under the main led lens. Has anyone swapped it out for a white led? Which emitter did you use. There is access, and soldering isn't a problem. Just curious if anyone else is out ahead of me.
