Here my thoughts about the SR3 :
The light looks tough and well crafted. The selection ring works as it should, it switches easier between level 5 and 6 or 6 and 7, but no major problem. It can be operated with one hand. Inside, it looks well done too, serious contacts and brass plates. The reflector looks nice, the LED is centered.
Minimum is low, but could be lower. The Liteflux LF3XT is by now the only light I can use at night to go to the bathroom (except the Gatlight, but that one stays in its box, the Clickies are not programmed on the lowest mode). The first 6 modes are well stepped, but you don't see much difference between 6 and 7 and hardly any difference between 7 and 8. So, I would like to see level 7 as level 0!
I managed both to activate strobe willingly and unwillingly (a few times). I'm pretty sure that I didn't swif that ring back and forward in less than 2 seconds, but I suppose in normal operation it'll be OK, while testing you act different. I also noticed that sometimes it is switched off after turning the light off and on again, sometimes not. Well, personnally i don't really care, i only hope the strobe will stay where it initially is : hidden!
The beam is nice, well balanced, bright, tight hotspot. In comparison with a TK10, the hotspot is smaller, but brighter. The spill doesn't seem that bright, but still OK for a universal light. Compared to the PD20, the hotspot is larger and brighter, more spill. 😎
In size, the SR3 can be compared to the odd looking EagleTac T10C, the diameter of the lens is about the same, the SR3 isn't so small down the reflector because of the selection ring. It also is quite heavy.
I bought the light because I immediately fell in love with it when I saw it. For my big hands, the size is the right one, but because of its thickness, it won't replace any Clicky in my pocket for sure, those are the largest I actually want to carry in a trousers-pocket! 😱
