Moderators: This thread is intended for the Flashlight Reviews forum.
I've been carrying my Fenix LD20 day-in, day-out for close to three years, and it still works like a charm. More recently, though, I've been thinking about upgrading to 18650 to get better performance and runtime. After a bit of thought, I ultimately purchased a Nitecore SRT7 Revenger from B&H, along with a 3400 mAh Nitecore protected 18650 battery (model NL189) and Nitecore Intellicharger i2. I don't intend to cover the more technical aspects of the flashlight such as measured brightness or runtime (for that, there's selfbuilt's review), but here's a review that focuses on the more tangible aspects of the light.
Design and build
Pentax K-5 with DA 18-135mm @ 100mm. Av, 1/160s f/13 ISO 400. Bounce flash from ceiling. Processed from RAW in RawTherapee.
Nitecore SRT7 Revenger: Size Comparison by DragonLord878, on Flickr
User interface
Performance and operation
Overall, this is an excellent multipurpose tactical flashlight, and I'm glad I decided to step up to 18650 lithium-ion. This is a cutting-edge flashlight, the continuously-variable brightness and multitude of modes making the SRT7 a versatile light for a vast array of use cases. It's safe to say that the Nitecore SRT7 Revenger has dethroned the Fenix LD20 as my primary EDC light after nearly three years of continuous service. (I'll continue to carry my LD20 in my handbag as a backup light, but the SRT7 is what goes on my belt.)
Questions, comments, or concerns?
--DragonLord
Design and build
- The SRT7 is constructed from type-III hard-anodized aircraft-grade aluminum. Build quality is excellent, as good as or better than the LD20. All threads, as well as the Smart Selector Ring, are well lubricated out of the box.
- A single 18650 battery, two CR123A cells, or two 16340 (RCR123A) cells can be used with this flashlight. The positive contact uses a Nitecore proprietary design with a flat surface and recessed positive contact mounted on a spring. This design provides added shock and vibration resistance as well as protection against reverse battery insertion, but only button-top batteries will reliably make contact with the connector. The Nitecore 3400 mAh battery is slightly tight in the battery tube, but it does smoothly slide in and out of the light.
- Physically, the SRT7 is quite large and heavy for a single-18650 flashlight. Much of this bulk is in the large head, which contains an unusually large reflector which accommodates three RGB emitters in addition to the main LED and control ring (more on this below). It's about as large as I would carry for EDC, but some people may find it too bulky for this purpose. See image below.
- The SRT7 is rated as fully waterproof (IPX8) and submersible to 2 meters. As expected, no ingress or malfunction resulted after brief immersion in a small bowl of water. (A flashlight which is specified as waterproof but fails this test should be considered defective.)
- The clip is supplied detached from the flashlight and can be positioned for either bezel-up and bezel-down carry. Attachment and removal are both easy, and the clip fits snugly on the light.
- The holster is made of heavy-duty nylon, with a thin layer of neoprene on the flap and inside back. Quality is excellent, considerably better than the one which came with the LD20, and it should hold up to many years of daily use.
User interface
- The SRT7 provides continuously-variable brightness operation as well as standby, tactical strobe, beacon, red/green/blue color, and police warning modes. All of these modes are accessed through a magnetic (Hall-effect sensor-based) Smart Selector Ring (SSR) mounted on the head of the light.
- A large portion of the rotating range of the SSR is dedicated to the continuously variable brightness range, with about 105 degrees rotation from minimum brightness to maximum. The ring clicks at specific positions for the standby, maximum brightness, and each of the other modes. Full rotation range is about 315 degrees, with hard stops at each end; the ring does not rotate freely through a full 360 degrees. Physically, the SSR has moderate damping with a slightly rough feel, and the detents are reasonably firm.
- Despite the seeming complexity of the light, operation is simple and intuitive because all modes are accessed through the SSR. The tactical forward-clicky tailcap switch is long enough for comfortable momentary-on operation, while still allowing the flashlight to tailstand. The tailcap has anodized threads, allowing the light to be locked out against accidental operation.
- The continuously-variable brightness control is perceptually linear so adjustments are smooth and natural. It's not completely stepless as the brightness changes in steps when the ring is turned very slowly (most noticeable in a dark environment at low brightness settings), but the steps are fine enough that it's essentially indistinguishable from completely smooth adjustment during normal use.
- A small red indicator LED is present on the head of the light. The indicator blinks every two seconds when in standby, and during operation when the battery is below 50%. Low battery is indicated by rapid, continuous flashing of this LED. It's a nice touch, a simple and efficient way to indicate battery status.
- The SRT7 uses a T6-bin Cree XLamp XM-L2 LED and is rated to a maximum of 960 lumens. Although the manufacturer-claimed minimum brightness is 0.1 lumens, the light does not appear to run that low; my sample goes down to about 1 lumen when the battery is fully charged. All output levels appear to be current-controlled as PWM was not detected during testing.
- Both maximum and (to a lesser degree) minimum brightness are dependent on the state of charge of the battery. During my first use of the light, when the battery was 40% charged, and the SRT7 didn't appear to be outputting anywhere near 960 lumens. However, once I fully charged the battery, it was much brighter than my LD20. At the same time, the lowest setting became slightly brighter as well. I suspect an IMR battery (designed for high continuous discharge rates of 20+ amps) will maintain full brightness for longer.
- The beam pattern is very similar to that of my LD20, but with a slightly broader corona providing a smoother transition from hotspot to spill. However, the beam quality is not as good, with artifacts visible in the corona due to the cutouts for the RGB LEDs. I personally don't find it to be a problem in real-world usage.
- My sample of the SRT7 has a purplish tint, in stark contrast to the greenish output of my LD20. To my eyes, the output of the SRT7 is a bit more natural than what I get from the LD20.
- When turning on the flashlight at brightness settings less than maximum, and when quickly adjusting brightness, there is a smooth transition to the set brightness level. This "soft-start" behavior avoids the startling effect of sudden brightness changes and gives the light a bit of a sense of grace during operation. This ramp-up is disabled when the flashlight is set to max for use in tactical applications.
- A slight delay on the order of 0.15 seconds is observed when turning on the flashlight using the tailcap switch. This latency, which is probably caused by the driver electronics, is generally acceptable but may interfere with tactical use.
- At brightness levels similar to the LD20's maximum, the SRT7 runs very cool, only feeling slightly warm after several minutes of operation. The LD20 can get very hot if running at max for more than a few minutes. While the same can be said of the SRT7 when set to max, the higher efficiency of the XM-L2 emitter compared to that of the much older XP-G is evident in this reduced heat output. (The Cree XLamp XP-G dates back to 2009!)
- Although the RGB color modes don't provide very even lighting, they're nice to have and I can imagine useful applications for these modes.
--DragonLord
