Hmmm, I generally see almost all of the emphasis on throw.
The range in meters is a big selling point. I see a lot of lumen stuff of course, but, except for flashaholics, they don't know what that is. They generally know more is better, but, from what I see/hear, most think the range in meters advertised and the lumens are different ways of saying the same thing: "How bright it is", just like the wildly crazy Candle Power claims for the various spot lights arranged across the big box store's shelves; 15 Million Candle Power! (From a 55 watt halogen bulb, etc.)
I think the points about the throw at the 870 L output being short are completely in line with the light's shortcoming to many though.
All lights cannot do all things, there are simply too many design compromises.
A screw driver may be great at screwing in screws.,,,but, there will be those who complain how it SUCKS at driving in nails.
Why can't they make a screw driver that can drive in nails?
Well, they do, but, it makes it less good at either function to be able to do both.
The giant lumen out put is from giant honking LEDs...which also put out a lot of heat.
A larger LED has a larger point of emission, and, therefore, less throw for a given reflector size, etc. That means the lower output, smaller LEDs can more easily out throw the larger higher out put LEDs.
If they do it with less heat, great...and for those that want more throw, that's potentially a better overall solution.
If you WANT a wide floody and powerful beam, the MTG2 is a good way to go, if the resultant range/heat management limitations work for you too.
If you are ok with less flood to optimize range, you can take a smaller amount of light, and concentrate it into that smaller pattern, and get just as bright in the smaller area, but also project that beam farther.
I have an aspherical (Zoomie) MTG2 light that runs on two IMR 16340....which is my way of hedging the bet. That way, I get the ~ 3k lumen mule-like flood if zoomed out, and, zoomed in, a giant Eggo Waffle I can project onto more distant targets. I can also zoom to a TIR-like beam spot for intermediate targets.
