- Joined
- Mar 31, 2015
- Messages
- 5,360
Received TS10SG
Firmware is 714-2023-07-29, factory Defaults:
Arrived in Advanced Smooth ramping w Red Aux on High. Post Off Voltage Display enabled, no Smooth Steps.
I did a factory reset and the Aux changed to Blue on Low, in Voltage Display mode, still in Advanced Mode. (iow, someone had changed the Aux to Red High before shipping)
Battery check default uses Aux on Voltage Display Color. I changed it to Red.
There seemed to be no lube on O ring and threads, I added some Nyogel 760G, which made it easier to screw the light shut over the O ring.
7 Stepped modes in Advanced, 5 stepped modes in Simple.
Battery at 3.9V
Simple Ceilings are 750 lumens (130/150), Floors are 1 lumen
Advanced Ceiling in Stepped mode is 750 lumens (130/150), Turbo is 1000 lumens, Stepped floor is 1 lumen.
Advanced ceiling in Smooth ramping is 1000 lumens (150/150), Turbo is 1000 lumens. Floor is <0.01 lumens
(disclaimer, my lumen meter is homebrew and reads low, especially at max output, plus the output tests were done w the battery as received, not fully charged)
I think its a great little thrower, waiting for dark to do a bit more testing.
Compared to my MAO TS10 V1 modded by MasterNate to sw45k:
another view of the beam, that only shows the hotspot:
imo the little Tir works very well for its intended purpose and the little pearls on the Fresnel lens eliminates any rings in the perimeter.
Yes it has flashing pads:
I reflashed to a newer version of Anduril with Smooth Steps, and two digit voltage check. It is a custom hex thanks to u/SiteRelEnby with momentary deleted from Advanced and blinkies deleted from Simple mode. No issues reflashing.
Im thrilled with the TS10SG, its a very fun option.
BIG Thanks to Wurkkos for picking my name (along with 7 other people) in a random drawing from BLF.
Battery at 3.9V
