Hello all. First post here, long time lurker.
A few questions here. I built a light setup a few years back following simple instructions. I can follow directions, but I don't have enough understanding to deviate from the plans....so you guys can help me deviate!
This is the original project, built exactly the same way.
http://www.instructables.com/id/Ultimate-Night-Vision-Headlamp---500+-lumens-with-/?ALLSTEPS
Here is the summary if you don't want to read it:
I basically want to use the current buckpuck/battery setup to drive some more efficient LEDs.
More info on the buckpuck
1) Which LED's would you choose, and how many can this buckpuck and 8xAA (1.2v rechargeables) drive (2? 3? 4?).
2) Which reflectors would you choose for a mountain biking setup. My headlamp is setup for a more direct beam, so I want some spread for these (my handlebar setup). Also would my current reflectors/lenses work? I want to think they would, but I don't know if the luxeon lenses would work with newer LEDs (ex: CREE).
3) Any suggestions for mounting? Anywhere I can just buy a kit with the LEDs/lens/housing?
Thanks guys and gals, and I hope I didn't break any of the rules by posting this.
With the new LED lights available (and the discovery that these cyan colored LEDs aren't all they are touted to be) I am wanting to take the old LEDs off and upgrade to a more powerful/efficient setup.4 x Luxeon Star 1W Cyan (LXHL-ME1D or LXHL-ME1C) OR Green (LXHL-MM1C or LXHL-MM1D) - $3 each. (the circuit will work just fine with any color LED you want)
LED Dynamics Buckpuck (3021-D-I-1000 or 3021-D-E-1000) - $20
4 x L2Optics/Dialight OP-015 lens - $1 each
4 x L2Optics/Dialight OH-ES1-CL lens holder - $0.30 each
8x AA NiMH rechargeables
2 small toggle switches (digikey 519PB) - $1.50 each
Questions:One driver can power one or more Luxeon 1000mA LEDs with no additional circuitry or components
- DC input voltage from 5V to 32V. (The input voltage must be at least 2 volts higher than the forward voltage drop of all series connected LEDs.)
- 1000mA true constant current output regardless of the number of LEDs connected to the driver
