[ QUOTE ]
bucken said:
Can someone please explain (or link) how to check current draw? Search is not much help, but maybe need better key word(s). Thanks...
[/ QUOTE ]
Steps for checking current on your laser:
1. Unscrew the tailcap on your laser.
2. Set your multimeter to measure current. Mine has a fused setting up to 200mah and a separate unfused setting for up to 10A, so make sure you select the right setting.
3. Stick the negative probe of the meter under the pocket clip of the laser.
4. Press and hold the positive probe of the meter on the positive pole of the battery, compressing the spring.
5. Press the button to activate the laser and read the meter for the current drawn. /ubbthreads/images/graemlins/smile.gif
