slvoid
This is the 2nd time that this has happened. At first I thought I was just draining the batteries by accident turning it on while it was on my belt or something but then I turned the auto button lock on and same thing.
Came home tonight and:
1: Pressed on and the light just turned on (with the auto lock on). I know I haven't used it all afternoon and there's no way I triple clicked it by accident.
2: Turned it on and off 2-3 times.
3: Then I went to turn it on again and the light triple flashed me (the auto lock somehow enagaged itself while I was using it).
4: It wouldn't go any higher than 10 lumens or so.
5: I measured the battery at 2.6 volts no load and 0.8 (that's right) volts under a 3ohm load (a little under an amp, most new 3V batteries test 2.5-2.8V under that load, 50% used batteries are 2 and change).
I did the reset last time it did that and it apparently didn't do any good.
