* * * *Now at the Shoppe 2. Here's what's new.
Ms_SS
CA
The purpose of this thread is to announce new products as they become available. It is meant to easily see what is coming and what has been added to the Shoppe.
I would like to keep this thread limited to these announcement so people can see the new points of interest in a fast, at a glance way.
It is not for question posting. Please post in another thread or start your own.
Thanks
Cindy
Ms_SS
CA
McClicky2 is the new McClicky with 2 holes on top made for the McClickie pak. Works in the Aleph Tailcap as well.
Ti Clip for the Sundrop
Convex Lens for the SunDrop
May 2013 We are getting more Kroll Switches. ETA End of June
Ms_SS
CA
All Remora UIs purchased after June 30, 2009 have been re-programmed for 3-levels only, no SOS.
The Remora UI has been reprogrammed to eliminate the SOS flash state.
Ms_SS
CA
Flexible "Gooseneck" Stock Line
Single piece 6 inch flexible steel tubing with black vinyl coating and is threaded at both ends.
Dimensions: 0.36"OD x 6.0" long with 1/8-27 mbe threaded ends
Overall dim: 6.625" x .5"
Ready to use for task lighting and on fixed lighting parts.
kimck99
Hi,
Is the McClicky2 switch compatible with the Surefire C/G/Z series tailcaps?
Thanks
Ms_SS
CA
GDuP HIGH Output Converter (with OPTIONS) NEW
Runs up to 1200mA
The original GDuP is the mizer version ~700mA
Both GDuPs have options to customize levels. $9.00 each plus a text box to declare values.
When ordering be sure to log in first before choosing items with options. You will lose the options in your cart if you log in later. If this happens, delete the former part and add the desired part with all options. Don't forget to add labor (solder, ream, etc) value.
Ms_SS
CA
The GDuP high output 3 level driver runs the more high powered multi-die LED, like Osram quite nicely.
brandocommando
Oregon
Just ordered a McR-19XR reflector (top secret project,):cool: some AATA, and some AS5.
Thanks!
P.S. I think I ordered the last AATA...
Ms_SS
CA
We are adding a new Category to the Shoppe
[h=1]Non-Custom Lights & Stuff[/h]Generic flashlights, accessories and other items as they come in
Ms_SS
CA
