gcbryan
My specific questions are referring to this light:
http://www.dealextreme.com/details.dx/sku.26498
I realize this isn't a light that most of you are all that fond of nevertheless I could still use some general advice.
Picking out appropriate o-rings and relative strength of various lenses...how do you know what durometer is appropriate. In this particular case there are two soft silicone o-rings in the removable tail cap area. Soft means they will seal easily under lower pressure but it also means they could "bottom out" under higher pressures and leak. How do you know which duro would be an improvement without being so stiff that they would leak under lower pressure?
The 50mm x 2.5mm "coated glass" lens is not something that can be replaced with a thicker lens due to the limited thread free area in the head but is there a stronger lens material that could be used...Plexiglas or something still being limited to a thickness of 2.5mm?
There haven't been a whole lot of floods in these lights so I'm really just trying to learn a little more on this subject. If I can make easy fixes great but if not it's still good info to have.
Any Mechanical Engineers out there or anyone else with some info?
Thanks.
Thanks.
