Recently, I noticed twice the same odd behavior of my Fenix L2D (P4-version):
When playing around with it and after turning it off, the light turns on in the low mode and refuses to change to a higher mode. Turning the head for turbo doesn't change anything, still on low.
Every half-click of the switch causes the light to flash once, but it stays on low.
After leaving the light off for a couple of minutes, it seems to recover and works as it was meant to.
My first simple assumtion was, that the light was overheating and some thermal protection kicked in. However, the light seemed only slightly warm to me, when the failure occured.
Has anyone noticed a similar behavior? Do you think this is still o.k. or do I own a flawed version? :shrug:
Since the problem seems to resolve itself after a while, I can still use the light, but it bothers me to have a light which might not be fully reliable.
Greetings from Germany,
AlexK
AlexK
