Older Ni-Cd charger for NiMh?
Wits' End
Remote NEast Minnesota, next to Lake Superior
I have an Archer (Radio Shack) 23-139 DC battery charger. How bad is it to use occasionally for charging newer NiMh's?
Specs: input DC 11-16v 6W Output DC 2.7V/8.6V 150mA max Date: Jan-Mar 1986
Just found this cleaning my tool area. Looking at this as an extra charger not my main.
TIA
From the voltage of 2.7 V it looks like you would need to charge cells in pairs, and from the charge current of 150 mA you would need to charge on a timer.
Since 150 mA is below the 0.1C rate for most AA NiMH cells you could charge them safely, but using a charging time of (1.4 x capacity)/150 it would take some time. For example it would take 1.4 x 2000 / 150 = 18 hours to charge AA Eneloops.
Only you can decide if that's worth it.
Nope. Not for NiMH. However, keep it. I find NiCd AA and AAA to be extremely useful, versatile, tolerant of abuse, not to mention cheap.
I think it'll work OK, using Mr H's formula. I have a 6 Bay (2 single + 4 bays that take 2 in series, or 10 cells total) that I occasionally used. It has the same 150mA rate (50mA for AAA's). I figured it was pretty close to a forming charge for 1800's and probably, at least, not damaging for 2000's. Now that I have 3, C-9000's, I probably won't be using it any more. :)
As long as the charge rate does not exceed 0.1 C, NiCd chargers will work with NiMh's, using the formula. As has been mentioned, it will take a while.
Dave
I thought the rule was that you could use a NiMh charger to charge NiCd cells, but you couldn't use a NiCd charger to charge NiMh cells.
More specifically, fast NiCd chargers that rely on -dV termination should not be used with NiMH, but slow chargers that use a constant charging current less than 0.1C are fine, as long as you stop charging at about the right time.
NiMH cells can take a 0.1C overcharge for quite a long time (hours, not months) without damage.
Not "As-Is"!
I just GOOGLE'd the Part Number you gave (to see if I could find some 'Tech Specs' or a Manual) and it came back with:
3.7V/1000mAh Li-ion Battery for Sanyo 8300 (Red)
Is 23-139 the correct Part Number?
On the other hand, based on it's age (~23 years), is it TIMED or DUMB?
  • If it's TIMED, you'll (probably) have to RESTART it (one or more times) to fully charge CURRENT NiMh cells.
  • If it's DUMB, you can safely pump 150ma into a 1500mAh cell for 16 hours, or into a >1500mAh cell (i.e. a 2000mAh LSD) for a bit longer (2000mAh / 150ma * ~1.6 = ~21.3hrs)
Personally, based on my recent reading of the ARCHIVES here at CPF, I just dug a few old DUMB / TIMED chargers out of storage in an attempt to rejuvenate / de-crystalize some NEGLECTED 1300mAh, 1600mAh and 2000mAh cells. You can use an OLD charger to recharge NEW cells *IF* you understand WHAT you're doing. BUT, personally, I wouldn't use an OLD charger on a regular basis. I'd use a NEWER charger that could provide 0.5-1.0C with -dV termination... ;)
