markr6
- Joined
- Jul 16, 2012
- Messages
- 9,258
I think you are making a few assumption about discharge rates. You need to understand there is a difference between a peak and a continuous discharge rate.
But also reflect that for high output flashlight use, you also want something with the most stable voltage you can get. Most torches do not exceed the discharge rates of many batteries, but performance can be hugely different.
For example, take a look at these discharge curves. If you've not used these graphs before, you essentially want the line to stay as high as possible for as long as possible. The higher the line, the less voltage sag and the better and more consistent output you'll get from High and Turbo modes on your flashlight.
The total length of the line only really matters for moonlight and low modes. Not too mention once the voltage drops below a certain point it's all pretty redundant as the LED's require a minimal vf to operate at all.
I take the lower capacity cell every time out of these two.
Great post and "summary" of how to read these. Good choice on comparing the two cells also. I think most people would recharge the battery well before ~3.25v anyway, so there is hardly an advantage on the 3600mah cell.
