Dry-cell
CPF has gotten me more interested in flashlights. Their much better than they use to be. I'm trying to choose between these two, I chose them mainly because they use two AA batteries rather than Lithium-ion (which are pricey). I already have Sanyo Eneloops and am waiting to receive a Powerex MH-C9000 charger. The flashlights are both in my price range at the moment.
The T25 has better output than the I25, but the I25 has better throw. The T25s construction is stronger.
I'd like to have a wide beam for path illumination, rather then concentrated directly in the center. But I don't think I'd get that with these slim flashlights. Compared to the Fenix TK40, which I'd love to own!.
Which has less problems in terms of part ware?. Is the switch going to last?, what about the head that you turn to change the beam modes?, will I have any problems with it over time?.
There's quite a few spelling errors below...
Product name: I25 Infinitum
Item No.: I25
Product Description
* World-class super bright Cree XR-E R2 LED
* Modes: Illumination (Digital infinite beam adjustment) 205lm/1.5h--
6lm/80h---Strobe---SOS
* Max 200 meters/ 219 yards/ 656 feet long throw
* Max 205 lumens output
* Max 80 hours long runtime
* Tactical momentary-on forward switch, protruding switch for easy
momentary or click to lock on
* Auto memorization of the current birghtness level when power off
* Linear functional adjustment for easy change of functions
* Superior heat sink that disperses heat to protect LED and electrical
components
* Ergonomic design with solid structure for easy operation
* Orange peel reflector for flawless beam.
* Strong / quick to release lanyard to prevent loss and easy access
* Mil-spec: MIL-STD-810F
* Highly Water resistant
* Anti-shattering ultra clear lens, anti-scratching and anti-slip
* Lock-out function to prevent accidental activation
* Engineered anti-slip body texture that give you a firm tight grip
Specitication
1. Uses the Cree 7090 XR-E
2. Uses 2XAA batteries / 2X1.2V Rechargeable batteries
3. Dimensions: Length: 155.8mm , Diameter: 25.8mm
4. Color: Black
5. Weight:: 90g without batteries
Product name: T25 Tactical
Item No.: T25-T R5
Function Three Brightness Levels and Strobe
Specifications
LED: Cree XP-G R5, life span up to 50000 hours
Maximum output: 210 Lumens.
Battery: Uses 2x AA 1.5v Alkaline or NiMH Rechargeable 1.2v batteries.
Dimension: L 153mm (6.02’’) x D 22.8 mm (0.90’’),
Weight: 72g / 2.54oz (Excluding Battery)
Function Three brightness levels 210lm(50minutes)-110lm(170minutes)-14lm(108lm), Strobe.
Accessories included: Holster, Lanyard, Spare O-rings and Spare rubber switch boot.
Accessories optional: Filters (Red, Green or Blue), Beam Diffuser.
Features
* Ultra high performance Cree XP-G R5 LED provides Shock-Proof dependable lighting.
* Tactical click-on/off switch with momentary on function.
* Full textured reflector for flawless far reaching beam
* High Output, 210 lumens max
* Uses regular AA batteries as a convenient easy power source.
* Ultra efficient advanced digital power management system for smooth
and even brightness over the duration of battery life.
* Three Digital regulated constant output brightness levels plus Strobe
* User friendly interface, loosen then tighten head to select desired output level or mode.
* Automatic memory function, remember last used setting & will come on at same level as when turn off.
* Solid aluminium construction, Ergonomic design with anti-slip knurled finish for firm grip and easy operation.
* Tough durable Type III Hard Anodizing.
* Built to meet Mil-spec MIL-STD-810F.
* Ultra Clear Glass lens, non scratch with Anti-Reflective Coating.
* O-ring seals provide high water resistant and long service life .
* Stainless steel pocket Clip
Item No.: I25
Product Description
components
Specitication
4. Color: Black
Item No.: T25-T R5
Specifications
Features
