Hello fellow users of the CPF! If anyone has the patience to respond to my post it will be deeply appreciated as I am torn between two lights.
I have already published this post here but that was already a very specific topic so I think I should be better off starting a new one.
Let me quickly explain my situation:
I have a 10year-old Maglite, which takes 6D cells. It always worked wonders but it's heavy and long and I believe that lights have evolved a lot since then. Therefore I decided that I want a new, smaller light, still powerful (namely throw, although some spill can always come in handy) and regulated for hiking at night. These are the main purposes for the light.
After perusing the forum (which btw is superb) I have a final with these two contestants: Olight M20 Premium R2 and the Eagletac T10C2.
From my point of view, acquired from reading the forums rather than from experience, this is how I see the face to face:
M20 pros
- better throw (how much better can anyone say?)
- longer runtimes
- three output levels
- takes 18650
M20 cons
- lots of problems with off die or emitter
- more expensive
- some reported problems with o-rings, flickering light as a low power indicator and almost useless warranty (although I think the two last have been or are on the verge of being corrected)
- green tint
T10C2 pros
- good throw (how good compared to M20?), very good spill and beautiful bright beam
- half the price
- tailstands
- neutral tint
T10C2 cons
- couldn't find out about the warranty
- no 18650
- no low low mode
I searched the forum for a comparison between both but found none. Do anyone have both lights? What's your thoughts? Could you post a nice comparison/beamshots?
MattK from Battery Junction replied to my post and was kind enough to explain that the low battery warning was removed, the warranty has changed and is more comprehensive and that only a few lights were affected with the green tint and non aligned die/emitter. Still, I would like some more opinions.
Thank you all very much
M20 pros
- longer runtimes
- takes 18650
M20 cons
- more expensive
- green tint
T10C2 pros
- half the price
- tailstands
- neutral tint
T10C2 cons
- no 18650
- no low low mode
