Sector7
After all that long wait and anticipation, I hope you are fully enjoying your torch Frenchy. :thumbsup:
Help Support Candle Power Flashlight Forum
#51 of 200 here in my hand today !!!
With diffuser 🙂
For the story of my light look at CPFM 🙂
With diffuser 🙂
44/200 over here in switzerland![]()
.... 042 just needed a second attempt to ramp down again...
Mine (127/200) tends to refuse ramping if the threads of the head carry too much silicone. I have noted that if I just lube the o-ring the light works perfectly well while if there is silicone on the threads or actually too much of it, the operation becomes somewhat uncertain.
It is exactly the same thing that happens with my NDI and for both lights the solution is to keep the threads free from silicone.
Armed_Forces,I personally prefer Krytox on Ti but most people cringe at the price. 😱oo: ..and for all the sickos that will ask, it's perfectly safe for O-rings!
Try some of THIS for thread lube and you'll never have to worry about continuity problems again. I personally prefer Krytox on Ti but most people cringe at the price. 😱oo:
+1 for Krytox, get the mix from the Shoppe - a teflon-based lubricant is pretty much mandatory for Ti. A small container will last you for the life of your light if not longer.
Also, I have read many, many, many a lube thread and one thing that there seems to be some concensus about is that conductive lubricants are totally unnecessary, and in some cases dangerous for flashlight applications (potential to cause unwanted electrical contact). Steer clear of these, imo.
Armed_Forces,Clive,
You might want to consider purchasing a custom blended Krytox lube from the Sandwich Shoppe.
I've never tried theirs because I have my own, but I thought I would link that because it's sometimes hard to find Krytox in small quantities.
Hello Armed_Forces,NO-OX-ID A-Special Electrical is an USDA approved conductive grease compound and rust preventive that prevent corrosion and lubricates electrical connections.
Incase nobody bothered to read the link.
The one I linked doesn't have any metals in it nor is the grease itself conductive.
Armed_Forces,
Thanks a lot for providing the link to the 5cc_Krytox_50/50 custom blend lubricant -- I really appreciate it! :goodjob: :thanks:
I haven't as yet compared its specs to those of the ol' faithful NyoGel_760G that I've been using for the past several years. NyoGel has worked beautifully, but if Krytox is even better -- then it'll be my next go-to o-ring and thread lube.
-Clive
