Fallingwater
With all the LiIon cells of various shapes I have kicking around (RCR123, 14500, 18500 and a gaggle of different prismatic ones) I obviously couldn't have a separate charger for every size.
I was faced with a choice: either get an expensive computerized charger meant for RC use or come up with some sort of homemade hack.
Since I got a RCR123 charger along with the RCR123 cells, I decided to go for the hack.
LiIon cells all need the same charging technique, and (in contrast to NiMH) there can be no dumb charger for LiIon.
So any LiIon charger can charge any LiIon cell; all the difference between, say, a charger for RCR123 and one for 18650 is in the size of the battery receptacles. Well, ok, a 18650 charger probably charges at a higher current, but if waiting isn't a problem any small charger will do.
So I opened the RCR123 charger, soldered two wires to the connections for the battery contacts, and this is what came out:
That's a 18500 cell, with wires held in position by hard drive magnets, being charged by the RCR123 charger.
It takes a while to charge larger cells, but it works just fine.
