raj, I have noticed on some bmw housings, that they specify that the headlamps were designed for H7/D2R bulbs.
No, you're misunderstanding the markings. Many headlamp designs share a lot of components among the various versions. Generally these include the brackets, the outer lenses, the bezels, and other non-optical components, with only the functional parts such as optics and aim adjustors being different for different versions (halogen, Xenon, USA, ECE with right traffic, ECE with left traffic, Japan; with levelling, without levelling). So, you will often find the fiducial markings for all different variants of the headlamp on each individual headlamp -- you find for example the ECE type approval markings for halogen and Xenon versions for left and right traffic, plus the USA DOT marking, and you might find the Japanese JIS marking as well, and the Chinese CCC mark. This
does not mean the one headlamp you're looking at meets all those requirements. It's a real problem because it's no longer possible in many cases to determine which of the many markings apply to the particular headlamp being examined; there are various proposals to simplify and clarify the markings, but for now the trouble is that worldwide regulations say that as long as the applicable markings are present, any other markings are also permitted. This was not a problem when there was technically no possibility to share components among significantly different lamps, but now it is. The important thing to keep in mind is that there is
no such thing as an optic that's compatible with either a halogen or a Xenon bulb, and the differences are far more extensive than just a different bulb holder.
